HELP!! 2000 mustang stereo install!!! - Mustang Evolution
Old 06-06-2012, 10:05 PM   #1
Steezy's Avatar
I have been sitting in my mustang for 5 hours now trying to pull out the factory radio to install a new one and it will not budge. I bought the removal tool and the radio still will not come out. Someone please help...
Steezy is offline   Reply With Quote
Old 06-06-2012, 10:06 PM   #2
It's not me, it's you.
primer2tone's Avatar
Is the removal tool the two U shaped pins?
Old 06-06-2012, 10:07 PM   #3
Steezy's Avatar
Yes! I bought it from auto zone or 7 bucks and the guy said it was so easy to do his kid could do it.. And he couldnt
Old 06-06-2012, 10:09 PM   #4
Steezy's Avatar
This is my current progress
Old 06-06-2012, 10:13 PM   #5
Try popping that outer trim off. It might be overlapping the stereo. Also, wiggle those pins left and right. They might not be releasing the clips properly. It may just need a good tug on the clips to get it loose.
Old 06-06-2012, 10:16 PM   #6
Steezy's Avatar
Oh we have given it a tug alright... And it will not come out. We also tried popping the trim off but only the two clips on the tip by the air vents will pop but the bottom wont
Old 06-06-2012, 10:24 PM   #7
Are there any screws at the bottom of the trim? When you pulled on the tool, does the stereo budge at all?
Old 06-06-2012, 10:27 PM   #8
Steezy's Avatar
There are screws, we took them out. Then the stereo moves left to right but not out.
Old 06-06-2012, 10:31 PM   #9
I think you gonna have to get that trim off. Try popping the trim out from the bottom first.
Old 06-06-2012, 10:32 PM   #10
Steezy's Avatar
We already tried that but it wont come out...it seems as though the bottom cd player holds it in
Old 06-06-2012, 10:34 PM   #11
Can you pull out the bottom cd player?
Old 06-06-2012, 10:39 PM   #12
Steezy's Avatar
Nope, not budging. Same as the top radio
---------- Post added at 10:39 PM ---------- Previous post was at 10:35 PM ----------
I'm about to just give up. Nobody can get this thing out and or knows how.
Old 06-06-2012, 10:47 PM   #13
Try switching the U tool maybe they are not in far enough.
Old 06-06-2012, 10:48 PM   #14
Steezy's Avatar
We put them in as far as they could go one time...did nothing
Old 06-06-2012, 10:56 PM   #15
I did a quick search on YouTube and it showed you don't need to remove the trim. Maybe that tool isn't getting deep enough or the stereo is hella wedged in there.
Old 06-06-2012, 11:04 PM   #16
a3705872's Avatar
Re: HELP!! 2000 mustang stereo install!!!
Mine was a Mach 460 out of a 2004 but as I remember, I had to remove the trim around the shifter first(should pop out with a screwdriver), then I could remove the trim around the radio and air vents(1 piece). My stereo was held in by those clamps that require the hook tool and additional screws that are under the trim piece around the radio. That might be the case but yours is a different year. Hope that helps
a3705872 is offline   Reply With Quote
Old 06-06-2012, 11:20 PM   #17
Steezy's Avatar
Same video I watched. We even tried the nail method....I'm seriously so aggravated
---------- Post added at 11:20 PM ---------- Previous post was at 11:12 PM ----------
When I try to pop the trim off the top clips by the air vents come off but the bottom two won't
Pop out down by the cd player
Old 06-07-2012, 12:07 AM   #18
You can't take the trim off till the radio is out because off the torx screw behind the radio. The easiest way to get the radio out is to insert the tools till you hear a click if you push the clips too far the radio won't release. When you hear the click push driver side tool toward the drivers door and passenger side toward passenger door and pull radio out. If you still can't get it out get a putty knife under the radio and wiggle.
homeslice18 is offline   Reply With Quote
Old 06-07-2012, 12:29 AM   #19
Steezy's Avatar
Alright I'll try it tomorrow and let you know. Thanks guys !
Old 06-07-2012, 08:03 AM   #20
V6 stang's Avatar
Mine was a ***** too. I ended up taking it to the geek squad cuz I got so annoyed I was going to break some part of something in there. Even they had trouble with it tho and they do it every day lol. Removal tool sucks *** tbh
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 06-07-2012, 09:17 AM   #21
mustangg2000's Avatar
Region: Arkansas
Pull trim off take out screws with a star bit it comes right out.. I did it came out fine I have a 2000 model Stang as well.. Easy
mustangg2000 is offline   Reply With Quote
Old 06-07-2012, 02:38 PM   #22
Steezy's Avatar
I cant take the trim off...the bottom two clips will not pop. I got the cd player out and now the clip too release the radio on the right will pop but the one on the left is jammed. We are using our hands to take it off
Old 06-07-2012, 03:11 PM   #23
FordAddict's Avatar
You have to make sure they are all the way in the. You either push them apart from the stereo and pull or push them together and pull.
<- Π [ ] Π ->
Or
-> Π [ ] Π <-
FordAddict is offline   Reply With Quote
Old 06-07-2012, 03:28 PM   #24
Steezy's Avatar
The tabs will not go in! I was told I have to destroy the factory radio because the tabs are broken
Old 06-07-2012, 03:30 PM   #25
FordAddict's Avatar
What do you mean they wont go in??
Old 06-07-2012, 03:39 PM   #26
Region: Arkansas
Did u take out the lower two star bit screws that hold the trim to the dash
Old 06-07-2012, 03:46 PM   #27
FordAddict's Avatar
I didn't have to take out any part of the trim to replace mine
Old 06-07-2012, 04:35 PM   #28
Steezy's Avatar
I finally did it!! Me and my freind tore the faceplate of the radio and pushed the tabs using screwdrivers
Old 06-07-2012, 04:36 PM   #29
FordAddict's Avatar
Nice! Now slide in the new sucker and blast some tunes!
2000 mustang
01:31 PM
