02 GT Mach 460 Ate CD - Mustang Evolution
Old 06-14-2012, 06:50 PM   #1
Greeny1Stang's Avatar
Just purchased a 2002 GT and went to put in a music CD that I burned. The deck wouldn't play the CD and now I can't get it to do anything. Any ideas on how to get it out? I have tried somethings that I found on the internet but they didn't work. Some have just recommended to replace the deck because the stock decks are known for this problem.
Greeny1Stang is offline   Reply With Quote
Old 06-14-2012, 07:05 PM   #2
Rm360's Avatar
The last time this happens to me I hit the eject button and chose the slot the disk was installed, after it went through the motions and stopped I used a all flat screw driver to open the door of the cd player you should be able to see the disk , then I just pulled it out with a pair of needle nose pliers, these units are notorious for this, hope it works for you !
Old 06-14-2012, 07:12 PM   #3
Re: 02 GT Mach 460 Ate CD
Thanks RM360. I tried prying open the door but i couldn't see any CDs. I tried cycling through the slots but there is no sound that is shifting through the slots.
Old 06-14-2012, 07:28 PM   #4
Rm360's Avatar
If the unit is not cycling through the slots try disconnecting the battery for about 10 mins the cd player should cycle when you connect the battery , these things are a real pain !
Old 06-14-2012, 07:45 PM   #5
Thanks! I'll give that a try tomorrow.
Old 06-14-2012, 08:06 PM   #6
Rm360's Avatar
If you get it post up how if you can , it seem every time this happens to me I have to try something different , pretty soon I'm gonna use the hammer and smash method! Lol!!!!
Old 06-14-2012, 08:11 PM   #7
natebomb23's Avatar
You can also try and pull the radio out and unplug the harness and that will totally reset the unit and once u plug it back it it should spit out all cd's that r n there.
What doesn't kill you will only make you stronger!
natebomb23 is offline   Reply With Quote
Old 06-17-2012, 08:03 PM   #8
Well I tried disconnecting the battery and then connecting it back. Unfortunately that didn't work. Tried opening the front and seeing if I could see the CD but nothing. From wht I have read this is a common problem with the stock unit. So I am just going to buy a new unit with bluetooth.
Thanks for the help though!
Old 07-26-2012, 08:59 AM   #9
Blogger
99ford's Avatar
Originally Posted by tonina911
yeah just replace it its not worted fixing it plus a new deck has better sound quality and funtions like mp3,ipod connection,aux,bluetooth,and more
+1 the Mach audio is notorious for this.
Old 07-31-2012, 05:54 PM   #10
Mylo0280's Avatar
+1 for new deck.
Mylo0280 is offline   Reply With Quote
10:00 PM
