Iphone videos on navi screen - Mustang Evolution
Old 06-20-2012, 06:37 PM   #1
Struego's Avatar
Anyone have any luck with getting video from from the iPhone to play on the navi screen? When I try this on my 2011 gt, I get a message on the phone that video is playing on other device, but it's not.
Struego is offline   Reply With Quote
Old 06-23-2012, 08:33 PM   #2
Adogg's Avatar
Usually if installed correctly no screens in the front of the car are not allowed to play videos it is against the law in most states so most likely its not going to work unless ur e brake is up and not moving
Don't hate....... appreciate
Old 06-24-2012, 10:02 PM   #3
Jake's Avatar
Theres a relay that can override that.
Jake is offline   Reply With Quote
Old 06-25-2012, 01:55 PM   #4
05MUSTANG4.0L's Avatar
Im guessing it looks like this
ID:	56424   Click image for larger version
05MUSTANG4.0L is offline   Reply With Quote
Old 06-25-2012, 02:05 PM   #5
Jake's Avatar
Yes sir,
Old 06-25-2012, 04:07 PM   #6
Struego's Avatar
I actually have the factory sync navi screen.
Old 06-26-2012, 09:35 AM   #7
Just cut the video ground cable that's connected to park and connect it to amy ground you can find
irving91605 is offline   Reply With Quote
Old 06-27-2012, 12:53 AM   #8
Just put together a relay for it you can't just ground the cable from the ebrake because it needs to have a little switch that turns it on and off. Look up ebrake relay or check out Sound Man audio that's where I learned how to do mine they have a YouTube channel its not that hard and most of the parts you can get from your local auto shop
Mustangrtrx is offline   Reply With Quote
Old 06-27-2012, 04:36 AM   #9
Jake's Avatar
Right, cause im pretty sure everytime you turn your car off then back on it resets itself so you have to flip the switch evertime
Old 06-27-2012, 09:36 AM   #10
Yea it kindof resets but you never have to flip a switch what happens is the relay does the switching to imitate the amount of power used by the ebrake so it looks like the ebrake is pulled. Basically you wire up the relay and I tested mine before I put it back in but you will here a little click... That click basically means that the power is switching over so the deck assumes the ebrake it pulled
05:26 PM
