subs in trunk - Mustang Evolution
Old 09-23-2012, 03:40 PM   #1
RhoudezGt's Avatar
subs in trunk
does the trunk rattle with subs on a 2013 gt
RhoudezGt is offline   Reply With Quote
Old 09-23-2012, 04:15 PM   #2
DWC_SmOziLLa's Avatar
Very minimal. You really have to be cranking it.
Old 09-23-2012, 07:15 PM   #3
RhoudezGt's Avatar
Well its gonna be a 12" kicker L7 that's why I was asking.
Old 09-23-2012, 07:27 PM   #4
With that, I'm sure it will. I was more talking about my experiences with the factory sub that comes with the shaker pro system.
Old 09-23-2012, 07:40 PM   #5
RhoudezGt's Avatar
Is there anything I can do to prevent it?
Old 09-23-2012, 07:54 PM   #6
2013_stang_gt's Avatar
dynamat your whole trunk and your good to go
2013_stang_gt is offline   Reply With Quote
Old 09-23-2012, 09:46 PM   #7
Delta vt's Avatar
Not too bad. I have 1 10" JL sub in the back seat. There is not much rattle to speak of.
Delta vt is offline   Reply With Quote
Old 09-23-2012, 10:42 PM   #8
Napoleon85's Avatar
Re: subs in trunk
We're talking about totally different levels here ... OP - there is not a car in the world you can throw that sub in without rattle. That sub is (under)rated for 750W RMS, and will be rattling every single piece of metal on the car at significant volume. The Mustang build quality is shaky at best, and more designed for performance than SQ. If you are concerned about rattles and squeaks then you should be looking at dynamat and extra sound deadening all round the vehicle.
PS - You might want to check out the Mustang Audio & Video forums for further information on this topic, as it is more appropriate to your question.
Old 09-23-2012, 11:24 PM   #9
xhgwx's Avatar
I have a 12" L7 running 600 watts.
Then 4 new speakers thru out the car each running 80 watts and it rattles a little, u can't hear it to much out side the car but if I blast it u can.
I can't turn it up more than 4 notches with out hurting my ears.
xhgwx is offline   Reply With Quote
Old 09-24-2012, 07:08 AM   #10
Re: subs in trunk
If you put a subwoofer in the trunk of your car, in the traditional box firing back design, it's going to rattle. Dynamat 20 layers thick will not stop it. Do not let anyone tell you otherwise. This is what I do for a living for 22 years lol. Dynamat is great for isolating midrange and midbass vibrations where the metal sort of rings and the mounting surface needs to be deadened. For bass, nothing is going to stop that trunk from rattling, unless you have a box designed to vent into the car and it is vented and sealed into the vent. So yes, an L7 is going to give you rattle and vibration, both inside and out. Although, not too badly since it is a single.
Grabber Blue "Betty" 2012 V6 Six Speed, 3.55, BBK cai/throttle body, longtubes, x-pipe, axle back w/oem tips, Lugo Performance Dynotune, Zex 100 dry. I need factory v6 foglight housings, and the stock 11/12 gt grill with the light housings.
WtFDiesel is offline   Reply With Quote
Old 09-24-2012, 07:40 AM   #11
all rattling can be prevented with dynamat. i layered my whole honda pilot. i was running (1) 12" Solo-X, (4) 12" L7's, powered by 2500 watt Kicker Z and 1000 watt Kicker Z amp. There will be flexing but thats normal, but rattling is poor installation and laziness that I can't stand.
Old 09-24-2012, 12:44 PM   #12
Re: subs in trunk
In an suv you are mostly correct. In the trunk of a car, the only way to prevent rattle is to force pressure into the cabin of the vehicle.
Old 09-24-2012, 02:43 PM   #13
lay one of the back seats down to relieve that pressure, and problem solved.
Old 09-25-2012, 11:07 AM   #14
True enough, probably stop 75% that way.
Old 09-26-2012, 08:33 AM   #15
GE3G's Avatar
I just added a 12 with a ported box and i can assure you it rattles and its only being pushed with a 200watt amp... It can easily be fixed with the dynomat because i found the plastic parts that are rattling... The rear view mirror rattles like a son of a bit*h also
GE3G is offline   Reply With Quote
Old 09-26-2012, 08:42 AM   #16
Indeed. Once you locate and trap all the plastics, and panels that are rattling, you can kill a huge amount. In some cars almost all of it. I literally dropped the gas tank, foamed it, and re-installed it on my 87 Grand National. At anything under 1/2 a tank of fuel and the tank rattled and rang. The next piece of advice: Do not let people upsell you. Unless you are heat shielding, aluminum backed deadener/asphalt tape is not necessary, and makes little to no difference in sound. Plain old mat. There are several brands, each is as good as the other. Dynamat, just happens to be the most known brand name.
Old 09-26-2012, 08:53 AM   #17
Unfortunately, there's nothing much you can do about the mirror. You can remove it, or mount it on your dash, lol.
Old 09-26-2012, 10:15 AM   #18
Nah, rear view camera and screen, get rid of the mirror.
Old 09-26-2012, 04:38 PM   #19
there you go
11:35 AM
