Jvc double-din receiver - Mustang Evolution
Old 09-25-2012, 02:47 PM   #1
Venomouz831's Avatar
Hey guys my jvc double din came in! I'll post pics when it's on!
)02 Gt, Founder of WE2G
Old 09-25-2012, 02:59 PM   #2
Quick question lol how do I take out the stock stereo
Old 09-25-2012, 03:17 PM   #3
Nvm got it off
Old 09-25-2012, 03:18 PM   #4
With Ford Radio Removal Keys. U Shaped utensils, prob get a set at wal mart for 5.00. Push them into the holes on the face of the radio until they click, then pull slightly apart, away from the radio, and slide out. Cage the JVC into the opening.
---------- Post added at 05:18 PM ---------- Previous post was at 05:18 PM ----------
Sorry, too slow lol.
Grabber Blue "Betty" 2012 V6 Six Speed, 3.55, BBK cai/throttle body, longtubes, x-pipe, axle back w/oem tips, Lugo Performance Dynotune, Zex 100 dry. I need factory v6 foglight housings, and the stock 11/12 gt grill with the light housings.
WtFDiesel is offline   Reply With Quote
Old 09-25-2012, 03:21 PM   #5
Lol it's goo thnks for the help! Now gotta do all these wires lol
Old 09-25-2012, 05:25 PM   #6
Jeezuz these cables are driving me nuts!! For some reason when the power is connected and as well as the ground when I try to connect it to the stereo it's trying to start the car confused?
Old 09-25-2012, 05:38 PM   #7
Um yeah. You should have used an interface harness, but if you cut the wires instead, here's the audio wiring chart:
Radio 12V- purple/lt. blue + radio harness
Radio Ground- black/lt. green and black - radio harness
Radio Ignition- black/pink + radio harness
Radio Illumination- lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on- N/A
Power Antenna- N/A
Left Front Speaker (+/-)- org/lt. grn - lt. blue/wht +,- radio harness
Right Front Speaker (+/-)- wht/lt. grn - green/org +,- radio harness
Left Rear Speaker (+/-)- gray/lt. blue - tan/yellow +,- radio harness
Right Rear Speaker (+/-)- orange/red - brown/pink +,- radio harness
Hope it helps. Radio wires should be in the manual, if not: Red=Ignition, Yellow=12v, Black=Ground, White set=Left Front, Grey Set=Right Front, Green Set=Left Rear, Purple Set= Right Rear.
---------- Post added at 07:38 PM ---------- Previous post was at 07:36 PM ----------
Oh, and if the radio has an illumination wire, it is orange with a white stripe. And it's illegal for the driver to have full motion video in sight, so no matter what, do not connect the light green wire to the ground, connect it to the parking brake like the instructions say, so you have to be stopped to watch video. Again, do not ground the light green wire, or you will have video in motion, and that is illegal.
Old 09-25-2012, 06:09 PM   #8
Thank you so much!! Tht helped a lot!! Everything is working now, only problem is my door speakers aren't working, but the tweeters and back ones are. I have a game so ima just have it like this for now.
Old 09-26-2012, 07:48 AM   #9
Yea, you have an amplified system then. Mach probably. At any rate, you have multiple plug in harnesses behind your radio correct? One of them is the harness that you found power and four speaker wires in, and then a smaller one, that you did not use. That is the amplifier plug for the factory amps. You need this: Metra Part Number 70-5519, this you can find online, or at any decent car audio shop, or best buy for 25.00 or less. It contains both harnesses, but you only need the smaller one with the RCA's in it. Plug and play. Hook the remote wire up to the amplifier remote out of the head unit. (The wire to the harness and the wire on the radio will both be blue with white stripe.) Then plug the RCA's into the corresponding outputs on your radio.
Old 09-26-2012, 03:34 PM   #10
Sweet!! Thnks again, I bought the product at best buy and got the amps working as well as the door speakers!
Old 09-26-2012, 03:42 PM   #11
Sweet. Glad you're jammin!!
Old 09-26-2012, 04:14 PM   #12
Thank you!
Old 09-27-2012, 07:12 AM   #13
Mweigt07's Avatar
Region: North Dakota
Oh, and if the radio has an illumination wire, it is orange with a white stripe. And it's illegal for the driver to have full motion video in sight, so no matter what, do not connect the light green wire to the ground, connect it to the parking brake like the instructions say, so you have to be stopped to watch video. Again, do not ground the light green wire, or you will have video in motion, and that is illegal.[/QUOTE]
Yeah and if your parking brake light does not work right you can add a switch to ground that way you can switch it off while driving
Mweigt07 is offline   Reply With Quote
Old 09-27-2012, 07:27 AM   #14
You would never attach it to the parking brake light. There's way too much voltage fluctuation, and you would eventually damage the ground sensing circuit in the radio itself, as the light wire would show a ground when the brake is applied, but with an incandescent bulb in socket, when you take the brake off, it would show positive. (Get out your multimeter/dimm and test it, I bet you I am correct on this) You would attach it to the parking brake wire, as close to the brake as possible, OR to the wire in the aftermarket harness if there is a provision. In that post, the parking brake wire part was pure sarcasm. True, but sarcasm. Because no one in their right mind would ever want to see video in motion. Plus it is illegal. You wouldn't want to go to prison for watching General Hospital while on the way to the track....
Old 09-27-2012, 07:36 AM   #15
Mweigt07's Avatar
Yeah that's what I meant because my parking break switch didn't work I don't know why I put light
---------- Post added at 08:36 AM ---------- Previous post was at 08:33 AM ----------
We always wire it to the park depending if it requires 12 volt source or a ground to activate the video
Old 09-27-2012, 07:59 AM   #16
Er, the only head unit on the market, EVER, to need a positive for video is Alpine. That is because you have to use the foot brake, and parking brake at the same time. Push foot brake (positive), put parking brake on and off three times leaving it on (that's the ground), then release foot brake. Other than that, ALL other video capable head units use a simplr ground for parking brake. Some need a switch on them as when you turn the car off, then re-crank, it will need to see the ground go away, then re-apply. That is mostly Clarion/Pioneer and certain Kenwoods. All the cheap ones, ie; Jensen, Phase Linear, Dual, etc, need the switch, but you can access the programming menu with the remote and bypass the lockout permanenlty anyway, negating the need for the ground all together.
Old 09-27-2012, 11:48 AM   #17
Oh ok thnks again. We grounded it but I doubt I'll ever watch a movie while driving lol
Old 10-02-2012, 10:19 PM   #18
Siendly22's Avatar
What size is your jvc bro?
Siendly22 is offline   Reply With Quote
Old 10-02-2012, 11:19 PM   #19
It's a 6.1 inch
Old 10-02-2012, 11:49 PM   #20
Siendly22's Avatar
It's a 6.1 inch
Thanks bro. Looks good. I'm planning to replace mine too .
Old 10-03-2012, 12:04 AM   #21
Kool thnks. It was only like 220 bucks
Old 10-03-2012, 08:40 PM   #22
Siendly22's Avatar
That's cheap! I saw a pioneer selling it online for $250 it's a 5.8 on the size.
What model of JVC you have so I can search what features they got. Thanks man
Old 10-03-2012, 09:36 PM   #23
It's a kw av50
Old 10-04-2012, 12:14 AM   #24
Siendly22's Avatar
It's a kw av50
Thanks
Old 10-04-2012, 12:21 AM   #25
Thanks
No prob
Old 10-17-2012, 08:46 PM   #26
zinc_yellow's Avatar
Region: New Mexico
I'm thinking about getting one of those too. My mach 6 cd changer always jams up.How hard was the install? I've installed a couple of cd players, but never one like this.
zinc_yellow is offline   Reply With Quote
Old 10-17-2012, 08:54 PM   #27
sLbxO143's Avatar
I have a double din pioneer in my car was $300 from best buy. I love it makes the interior look better and sounds awesome. Defiantly recommend.
http://instagram.com/p/NeZfi0pp-R/
sLbxO143 is offline   Reply With Quote
Old 10-17-2012, 09:11 PM   #28
It was super easy. Took about 1 hour or so
Old 10-17-2012, 09:21 PM   #29
Region: New Mexico
Wow wasn't expecting it to be easy. Do you have an alarm so it doesn't get jacked or is that even an issue? Ive had two cd players stolen already out of my previous cars
Old 10-17-2012, 09:25 PM   #30
No I dont have an alarm and my car has been tried to get broken to before but it was at a girls house I slept over. But its easy and for 230 bucks I felt it was a deal
Old 10-17-2012, 09:30 PM   #31
Region: New Mexico
Yea I was expecting atleast $400 when I saw the picture. Looks real nice I might message you or something if I get stuck when I start my install.
Old 10-17-2012, 09:45 PM   #32
No problem man I'll let you know this though you're going to need another harness from like best buy to connect it to the amps
Old 10-17-2012, 10:01 PM   #33
Region: New Mexico
How much was your harness
Old 10-17-2012, 10:16 PM   #34
20 bucks
Old 10-17-2012, 10:25 PM   #35
Region: New Mexico
Ohh thats not bad.
Double Din Headunit in an 05 GT Bamman Mustang Audio & Video 12 04-11-2012 10:02 PM
Best Double Din for 06 GT Solomo2 Mustang Audio & Video 5 02-18-2012 11:46 AM
ebay double din 03GT88 Mustang Audio & Video 11 09-22-2011 11:57 AM
12:32 AM
