iPod cable install on 2006 V-6 Pony Package - Mustang Evolution
Old 09-26-2012, 01:45 PM   #1
DAG 01's Avatar
Has anyone ever spliced in an iPod cable to the factory stero system on an 05-09? To my knowledge mine does not have any audio input jacks anywhere and I really want to keep the stock radio but just be able to use an iPod with it. Any help/advice would be appreciated.
DAG 01 is offline   Reply With Quote
Old 09-26-2012, 02:05 PM   #2
Jboogie's Avatar
Have u checked in the box between the seat for a inline Jack gt has one
Jboogie is offline   Reply With Quote
Old 09-26-2012, 02:10 PM   #3
DAG 01's Avatar
I believe I did a while ago but I'll check again. I don't think mine has one. I also think that some had the audio jacks and some did not for whatever reason.
Old 09-26-2012, 02:26 PM   #4
iSimple makes a nice interface. If you're inclined to splice or tap the oem harness yourself, here you go:
Radio 12V red/white + radio, 24 pin plug, pin 1
Radio Ground black/orange - radio, 24 pin plug, pin 13
Radio Ignition (CAN data bus)
Radio Illumination N/A
Factory Amp Turn-on dk. green/purple (F), gray/black (R) + radio, 8 pin plug, pins 4 and 8
Power Antenna N/A
Left Front Speaker (+/-) orange/lt. green - lt. blue/white +,- radio, 24 pin plug, pins 8 and 21
Right Front Speaker (+/-) white/lt. green - dk. green/orange +,- radio, 24 pin plug, pins 11 and 12
Left Rear Speaker (+/-) gray/lt. blue - tan/yellow +,- radio, 24 pin plug, pins 9 and 22
Right Rear Speaker (+/-) orange/red - brown/pink +,- radio, 24 pin plug, pins 10 and 23
Center Channel (+/-) N/A
Subwoofer (+/-) brn/org - red/blk (F), pink/lt. grn - org/red (R) +,- radio, 8 pin plug, pins 1 and 2 (F), 5 and 6 (R)
Aux. Audio Input Left (+/-) lt. green/black - dk. green/white +,- radio, 16 pin plug, pins 7 and 8
Aux. Audio Input Right (+/-) red/black - red/white +,- radio, 16 pin plug, pins 6 and 14
RSE Video (+/-) N/A
RSE Audio Left (+/-) red/white - white/black (satellite audio) +,- radio, 16 pin plug, pins 1 and 2
RSE Audio Right (+/-) orange/black - pink/black (satellite audio) +,- radio, 16 pin plug, pins 9 and 10
Satellite Radio 12 Volts red/white + satellite radio receiver in passenger side trunk
Satellite Radio Ground black/orange - satellite radio receiver in passenger side trunk
Satellite Radio Ignition (CAN data bus)
Satellite Radio Antenna (coaxial cable)
Satellite Audio Left (+/-) red - white +,- satellite radio receiver in passenger side trunk
Satellite Audio Right (+/-) orange - pink +,- satellite radio receiver in passenger side trunk
Grabber Blue "Betty" 2012 V6 Six Speed, 3.55, BBK cai/throttle body, longtubes, x-pipe, axle back w/oem tips, Lugo Performance Dynotune, Zex 100 dry. I need factory v6 foglight housings, and the stock 11/12 gt grill with the light housings.
WtFDiesel is offline   Reply With Quote
Old 09-26-2012, 06:47 PM   #5
Blogger
99ford's Avatar
I think it came about in 07 as standard!
However here is the diagram I used!
http://www.allfordmustangs.com/forum...4-capture8.jpg
Also I think the wire is 16 gauge??? So what I would do is go to Radio Shack and get you some wire taps
Old 09-26-2012, 09:36 PM   #6
I would still opt for an add-on iPod adapter, but, if you will wire it into the radio's aux capabilities....as a long time car audio installer, i would say to go to radio shack or best buy, and pick up a headphone (3.5mm) to RCA cable, about 6 ft long. Snip the rca ends off of it, then solder them into the corresponding radio wiring, run it under the console and bring it out throught the blank plate in the armrest pocket. Wire taps are def not the answer here. Or ever.
Also, your schematic is correct. What I gave you is the actual wire colors, making it easier for you to find the wires, either behind the radio, or where they may possibly be, under the center console near the blank inside the pocket.
Old 09-27-2012, 06:20 AM   #7
DAG 01's Avatar
Thanks for all your help guys. I'll take everything into consideration.
Old 09-27-2012, 08:35 AM   #8
IMO the best way to go is a simple aftermarket radio w/auxiliary or USB
Old 09-27-2012, 08:45 AM   #9
Quite possibly the best solution....we have a Kenwood for 99.00 with an iOS capable USB on the front, also has a 3.5mm (headphone jack style) aux input lol.
Old 09-27-2012, 08:53 AM   #10
^^^ that sounds like a win to me
Old 09-28-2012, 08:52 AM   #11
DAG 01's Avatar
I realize this. But I'd really like to keep everything looking stock.
Old 12-05-2012, 09:58 PM   #12
06v6mustang's Avatar
the only easy and nice way to do it is buy a headunit i have an 07 so i have the aux thing but then i installed a new headunit where you plug your ipod directly to the headunit
06v6mustang is offline   Reply With Quote
Old 12-08-2012, 09:59 AM   #13
Turtlestang39's Avatar
U should def buy a new head unit.
Turtlestang39 is offline   Reply With Quote
04:28 PM
