2002 Mach 460 tweeters? - Mustang Evolution
Old 10-07-2012, 09:41 PM   #1
Scream's Avatar
I have a 02 GT and with the Mach 460 audio system. (took the old amps out mainly just the speakers left) I put my own amp, subs and new radio in. Sadly I can't turn it up too loud because the tweeters can't handle the bass is there a way I can set them so they won't play bass? Or even I I have to can I upgrade to a tweeter that can? Anything should help!
Scream is offline   Reply With Quote
Old 10-07-2012, 09:56 PM   #2
Lorraine's driver
ab_mach1's Avatar
You need a high pass filter for the tweeters. Some radios have this feature built in where you can basically cut out the lower bass frequencies. Back in the day, you hard wired them through the speaker wires. What is your head unit?
Instagram: @ab_mach1
Old 10-07-2012, 10:06 PM   #3
Lorraine's driver
ab_mach1's Avatar
Here is some more nerdy explanations...
Passive Crossovers
High Pass Filter
You used to be able to buys these for about $15 each. Your wires from the radio would connect to the filter and then to the speaker. They used to have RCA patch cord high pass filters too. They would go between the radio and amp, with the RCA cables. I gotta believe they still sell them somewhere.
Old 10-07-2012, 11:35 PM   #4
1slosix's Avatar
my JVC unit has the option to turn down the bass so my tweeters don't freak out. check in your option menu..you may have it
carving corners like a boss
Old 10-08-2012, 05:45 AM   #5
Scream's Avatar
Ii can turn down my bass but it affects my subs to! Lol I think I found the "HPF" well see in the morning!
Old 10-09-2012, 06:50 PM   #6
Justasix98's Avatar
There is a little capacitor you can run in the positive wire feed to the speaker you can hook up, basically works as a high pass filter and cuts all the bass out of the speaker. I saw em on PartsExpress.com a while back, I'll see if I can hunt em down for ya
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 10-09-2012, 08:31 PM   #7
Scream's Avatar
It would be amazing if they had a tutorial also lol all you said right there ^^^ I got 2% of it
Old 10-09-2012, 09:44 PM   #8
Justasix98's Avatar
Your wire to the speaker has a positive and a negative. All ya gotta do is run this thing with the positive wire to the speaker lol
Just A Sixxer!
Old 10-09-2012, 09:45 PM   #9
Scream's Avatar
I can do that! Lol
Old 10-09-2012, 09:51 PM   #10
Justasix98's Avatar
Here ya are..
http://www.parts-express.com/pe/show...number=266-225
Just A Sixxer!
Old 10-09-2012, 09:54 PM   #11
Lorraine's driver
ab_mach1's Avatar
Originally Posted by Justasix98 View Post
We have a winner!
Old 10-09-2012, 09:55 PM   #12
Justasix98's Avatar
Hope this helps
Just A Sixxer!
Old 10-09-2012, 10:00 PM   #13
Lorraine's driver
ab_mach1's Avatar
Hope this helps
Spot on
Old 10-10-2012, 04:09 PM   #14
Justasix98's Avatar
What can I say, going fast just isn't right without music blaring through the stereo! Love my systems
Just A Sixxer!
02:12 AM
