Amp problem... - Mustang Evolution
Old 10-09-2012, 07:10 PM   #1
mustang06gt's Avatar
Amp problem...
Have a Cerwin Vega 1000.1 Stroker amp. I have it hooked up and running. The amp has a problem though. When I turned it up, the sub just had constant bass coming through it and quit playing music. I turned down the volume and still was doing it. I put the radio in Stanby and turned it back on. Still doing it. Got home and pulled off speaker wires and protect light turned off. Plugged wires back in and was fine. Normally when amps go into protect mode, they just quit producing sound all together. That constant bass coming through the sub is what is throwing me off. I know for a fact it is at 4 ohms, so no problem there. Enough size cable with 4 guage. All my wires are correct. Been wiring systems for 10+ years. It is definitely just an amp issue. Just wondering if anyone knows what the issue is with the amp? Someone said vibration internally would cause that, but they tried to fix it and now it's doing it again. Ideas???
mustang06gt is offline   Reply With Quote
Old 10-10-2012, 07:34 PM   #2
Anyone???
Old 10-10-2012, 07:41 PM   #3
Lorraine's driver
ab_mach1's Avatar
Could bad patch cables cause that? Is your ground good?
Instagram: @ab_mach1
Old 10-10-2012, 07:56 PM   #4
Yeah, I checked wiring with another setup. Definitely amp. Just don't know what???
Old 10-14-2012, 01:22 PM   #5
Sounds like signal input issue to me. Unplug the rca cables from the amp and see if it still has the the low freq buzz. If it does, it's the board, if not, it's the rca's. You can also try hooking up a different speaker as well, although that def sounds like a signal issue. WAIT!! Do you have a factory head unit, and using a line level adapter to convert to RCA? If that is the case, move the line level adapter away from the speaker, to behind the radio.
Grabber Blue "Betty" 2012 V6 Six Speed, 3.55, BBK cai/throttle body, longtubes, x-pipe, axle back w/oem tips, Lugo Performance Dynotune, Zex 100 dry. I need factory v6 foglight housings, and the stock 11/12 gt grill with the light housings.
WtFDiesel is offline   Reply With Quote
Old 10-15-2012, 05:54 PM   #6
I plugged another amp up to the speaker and no problems. That eliminates head unit and sub. Head unit is aftermarket bt the way. Definitely amp. Sound disappears when rca's are unplugged.
Old 10-16-2012, 07:49 AM   #7
Wanna replace that vega amp? lol , not a bad amp. Sorry to hear it went down like that.
Old 10-17-2012, 02:56 AM   #8
I know. I just need to let it go. Lol
Old 10-17-2012, 07:46 AM   #9
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
That happened to me once, i ended up rewireing my subs into a 4ohm and never had it happen again, also check your signal wire make sure thats in all the way and check your main fuse for your wires. I have a boss audio amp btw
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
03:53 PM
