subs - Mustang Evolution
Old 10-15-2012, 04:56 PM   #1
BrettHelm's Avatar
subs
Ok I have one alpine E 12" sub. If I get another 12 will it sound bad if it's not the same kind
BrettHelm is offline   Reply With Quote
Old 10-15-2012, 09:35 PM   #2
Jsmorley81's Avatar
It will not sound bad but may end up blowing one sub or the other. Even if its same rating. They will both Handel different. I would go with same sub you have already in
Jsmorley81 is offline   Reply With Quote
Old 10-15-2012, 09:36 PM   #3
BrettHelm's Avatar
Ok cool. Thanks. Do u by any chance know if a 600 watt amp will push 2 12s?
Old 10-15-2012, 09:54 PM   #4
Jsmorley81's Avatar
Yes it should push them just fine. I would run your speakers in a series to get the most amps to speakers. You can find a diagram on the Internet on how to do it. It's very easy to do. Hood luck should sound great
Old 10-15-2012, 09:56 PM   #5
emery2483's Avatar
it will push them, just depends on how loud you and them to be..
emery2483 is offline   Reply With Quote
Old 10-16-2012, 07:37 AM   #6
1. Yes, for two type E Alpine 12" subs, a true 600 watt rms amplifier will have them sounding good. Type E subs need little power.
2. Do NOT ever series your subwoofers unless you need to add the ohm loads together to get proper impedance.
First, determine what type of amp it is, and determine whether it's a single (mono) channel amplifier, or a stereo (two channel) amplifier, because, most (99%) of the two channel amps on the market are 4 ohm mono, or 2 ohm stereo capable. That 2 ohm, stable sticker means 2 ohms into two channels. Mono amps vary from 2ohm or 1 ohm most of the time. From here we have to determine if your subwoofers are dual voice coil or single voice coil, and what the ohm loads on those voice coils are. That will decide how your subs need to be hooked up. Post the information here. What brand and type of amp (model number if you have it) and if the sub woofers are single or dual voice coil. Single voice coil subs have only one set of speaker inputs. Dual Voice subs have two sets of speaker inputs. Once we know these factors, the hook up part is easy.
Grabber Blue "Betty" 2012 V6 Six Speed, 3.55, BBK cai/throttle body, longtubes, x-pipe, axle back w/oem tips, Lugo Performance Dynotune, Zex 100 dry. I need factory v6 foglight housings, and the stock 11/12 gt grill with the light housings.
WtFDiesel is offline   Reply With Quote
07:48 AM
