Sub question - Mustang Evolution
Old 11-08-2012, 11:48 PM   #1
NicholasP's Avatar
Sub question
Think one of my subs has blown and it's causing both not to work if I buy a new exact same sub and replace it will they both working again? Is there anyway they are wired that way or are they both blown?
NicholasP is offline   Reply With Quote
Old 11-11-2012, 09:03 AM   #2
V6in's Avatar
Check the fuse for it. Half the time that's what's wrong with mine.
V6in is offline   Reply With Quote
Old 11-11-2012, 09:08 AM   #3
Yes check the fuse and if have an aftermarket amp check the fuse(s) in it, also make sure if you have an aftermarket amp make sure it is turning on. Good luck!
Old 11-11-2012, 10:28 AM   #4
When you blew the one sub,,that probably drop the resistance in the circuit,,which causes higher amps,,which could have blown the fuse..Or maybe if they are tied in series,,it would be like the old christmas lights,,when one goes out they all go out
mymustang is offline   Reply With Quote
Old 11-11-2012, 10:35 AM   #5
Tpost08's Avatar
+1
Tpost08 is offline   Reply With Quote
11:21 PM
