STOP - Replace those door speakers - Mustang Evolution
Old 11-19-2012, 04:55 PM   #1
rm2092's Avatar
Order a replacement set of front door speakers for your Shaker 500 system. Sorry for starting another speaker thread but me and a friend just got done swapping out the front speakers and could not stop laughing HOW CRAPPY the stock speakers are. My iPhone weighs more then one speaker, I swear they felt like a plastic model kit. Oh yah I was bust today, oil change at my local dealer, resonator delete from my local exhaust guy and to finish the day off some window tint.
2016 5.0 Deep Impact Blue 300A pkg, New Orleans.
MODS: Roush axle-back exhaust, AEM DryFlow filter, Gloss Black PP wheels, Ford Racing Strut Brace, Track Pack spoiler.
New Orleans FaceBook Mustang Group
https://www.facebook.com/groups/NewOrleansS550/
rm2092 is offline   Reply With Quote
Old 11-19-2012, 05:20 PM   #2
gtstyles2's Avatar
Lol when I got my 11 new I swapped the speakers on the 3rd day... What a joke the stock speakers are... Never got around to doing the rear yet :-/ I think h gotta take apart the whole rear
Old 11-19-2012, 05:22 PM   #3
thejohncarlson's Avatar
The rear is not nearly as hard as it sounds. I just did my rear speakers and it took about an hour. It made a big difference, well worth the effort.
thejohncarlson is offline   Reply With Quote
Old 11-19-2012, 05:55 PM   #4
McQueen's Avatar
I have used my shaker less than 10 times since i got the car. I only use it for the sync handsfree.
Did you guys change it because it broke or because you didnt like the sound??
McQueen is offline   Reply With Quote
Old 11-19-2012, 08:14 PM   #5
You don't use your stereo?
It sounds much better with new speakers.
Old 11-19-2012, 08:28 PM   #6
IanM's Avatar
What kind of speakers did everyone use? Any particular kind, type, brand, etc?
IanM is offline   Reply With Quote
Old 11-19-2012, 08:37 PM   #7
I used Infiniti Kappas. They are great speakers.
Old 11-25-2012, 03:17 PM   #8
rebeltx's Avatar
Infiniti makes good stuff. I would also recommend JL and Alpine. If replacing the front shakers (I think there 8") I would go with JL all day. But keep in mind that the stock amp is probably way underpowered for aftermarket sub's. And believe it or not, it is just as bad to under power a speaker as it is to over power a speaker.
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 11-25-2012, 05:20 PM   #9
IanM's Avatar
Yeah, that's kinda why I was asking, my last car had stereo issues. I had a Trans Am with a Monsoon system which had an amplified system and was wired crazy. I never got that car setup correctly, so i'm not sure I want to mess around with this one until I know exactly what the deal is, what specs i need, and who has a proven setup that works well. After my last headaches, the last thing I want is to get into more of them...
Old 11-25-2012, 07:03 PM   #10
I have pretty much given up on replacing the door woofers. Since they have a really odd impedance (1.8 ohm) any replacements I have found would be higher and result in reduced output.
I believe these are the only 1.8 ohm, 8" woofers on the planet.
Old 11-25-2012, 08:00 PM   #11
Blogger
99ford's Avatar
Dang! If only I had the extra $ to replace them. Deluxe cones from china.
Old 11-25-2012, 09:41 PM   #12
Solomo2's Avatar
Shelby sells direct replacements for the door subs for $150. They are made by kicker.
Solomo2 is offline   Reply With Quote
Old 11-26-2012, 08:23 AM   #13
They are only direct replacements in the sense that they physically fit. They are still a higher impedance than the stock speakers and therefore have less output than the stock speakers.
Old 11-26-2012, 11:30 PM   #14
Solomo2's Avatar
What do you mean by less output? The few people I know who have them say they are louder and give off more bass without upgrading anything but the speaker. Curious, because they are what I am thinking of replacing my door subs with.
Old 11-27-2012, 11:52 AM   #15
1.8 ohms is close enough to 2 ohms that I think you would not have much of a problem dropping in some 8in 2 ohm speakers. But if your going that far why would you want to keep the factory amp?
Tec_ is offline   Reply With Quote
Old 11-27-2012, 11:55 AM   #16
I am by no means an expert at audio but, I know a thing or two about electronics so, YMMV.
Higher impedance means more resistance. For example, a 500w amp at 2 ohms is only 250w at 4 ohms. This won't be as dramatic since the Kickers are not double the impedance but, they are higher so, all others things equal, there will be less output.
Old 11-27-2012, 12:18 PM   #17
Correct but my understanding is that the sub amp in the shaker 500 is a 40x2.
My previous question stands. If your planing on putting new 8in subs in the doors why wouldn't you replace the factory amp.
Or disconnect them all together and run a 10 or 12 in the trunk?
Old 11-27-2012, 12:20 PM   #18
I'm lazy.
Actually, I am planning on running a sub in the trunk now. I was just looking for the easy way out.
Old 11-27-2012, 02:05 PM   #19
Solomo2's Avatar
I'm lazy.
Or Both!! I am working on getting a single twelve in the trunk and buying those Shelby door subs.
Old 11-27-2012, 02:34 PM   #20
I'm lazy.
Hahaha not to mention less expensive
I'm glad I'm not the only one who's thought about that.
Old 11-28-2012, 06:24 AM   #21
rebeltx's Avatar
IanM... Pre installed car audio can be a headache. In my time working with cars I always made sure to label every wire that was reliant before starting to pull anything apart, any big install place will do the same. If you would like, send me a PM or post your sub model and ill spec a proper amp for you. Install will be easy if you label, just use the existing wires, if you label properly it should be as simple as unplugging the factory amp and plugging in the aftermarket in it's place... Biggest problem here could be Makeing a new amp fit.
I think the best and safest way to go (but defnatly not the easiest) is going with the ol' sub in trunk.
Old 12-16-2012, 08:12 AM   #22
Villero1834's Avatar
Idk if the 2013 has a different setup but mine sounds pretty good and i got the one that comes with the base gt, not even the shaker 500.. I listen to pantera all the way up and theres no distortion whats so ever , i just need to add some lil tweeter and thats it im happy with the set , the base shakes my recaros
Villero1834 is offline   Reply With Quote
Power window stop working Xavier9370 1996-2004 Mustang GT 5 10-25-2012 09:38 AM
gonna stop fixing my crimson!! :( Vile87 Pre-2005 V6 Mustang 8 01-24-2012 07:49 PM
When should I replace Freeze Plugs??? FORDGT14 1996-2004 Mustang GT 5 11-30-2011 10:24 PM
this needs to stop stampde General Mustang Discussion 14 11-28-2011 12:56 AM
12:18 AM
