Radio resets every time I start engine - Mustang Evolution
Old 12-29-2012, 04:41 PM   #1
kfuson92's Avatar
Now, I know what you're all gonna do, refer me to another thread about a fuse being blown, the constant and acc power being switched, etc., but let me explain.
I got this mustang in a trade, and the PO installed a sony head unit, wiring looks alright, after market harness adapter it looks like, and all other wires were spliced in with quick connect tubes. The radio will turn on, I set stations, clock etc, and then turn the car off. Switch it trip acc on, and everything is still saved, it isn't until I actually start the engine that it resets. I've checked all fuses under the dash, checked for constant power, and acc, and everything seems to be on order. I am totally lost on this one. Amy suggestions? It does crank pretty slow, and the battery isn't the proper battery i don't think, it's got a mercedes benz battery?
kfuson92 is offline   Reply With Quote
Old 12-29-2012, 05:17 PM   #2
deadsp0t's Avatar
Bad battery and or grounding could be your issue if the fuses all in fact check out as well as the wiring.
Personally I'd identify the constant and be sure it is connected to a constant source.
That's unimpressive
Old 12-29-2012, 05:20 PM   #3
kfuson92's Avatar
Yeah I checked the constant with my test light, the yellow wire on the sony harness is constant, the red is accessory. I'll check the ground tomorrow. As well as get the battery tested.
Old 12-29-2012, 05:26 PM   #4
deadsp0t's Avatar
Check the block/batt ground as well. Maybe even unhook and clean them regardless how they look. Eliminating potential problem areas is how troubleshooting is done.
Your constant has power while you are starting the car as well?
That's unimpressive
Old 12-29-2012, 05:27 PM   #5
kfuson92's Avatar
Will do. I did not think to test the constant while I was starting the car, but that is on my to do list for tomorrow
Old 12-29-2012, 05:41 PM   #6
deadsp0t's Avatar
I'm no expert in wiring or electronics but troubleshooting is what I do.. Hope we can help. If we don't get you some help I will move this thread to the audio section.
That's unimpressive
Old 12-30-2012, 12:54 PM   #7
kfuson92's Avatar
Well, using my test light, I rested the ground connection behind the stereo, and it's fine, as well as tested the constant power while craning the motor. It dimmed while I started it, but never went completely out. Cleaned the connections to both battery terminals, and still no luck.
Old 12-30-2012, 06:39 PM   #8
Spaceghost's Avatar
The blue wire to ur memory is not hook up right make sure the diagram is right
Spaceghost is offline   Reply With Quote
Old 12-30-2012, 06:52 PM   #9
Jayjay's Avatar
100 bucks its the battery.
Jayjay is offline   Reply With Quote
Old 12-31-2012, 06:38 PM   #10
Justasix98's Avatar
The blue wire is a remote, used for running a seperate amp. In all honesty it really sounds like your acc/constant is reversed. Gotta remember the yellow wire is the ignition from the car but the ignition wire on your head unit may be red.
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
12:14 AM
