installing subs and an amp - Mustang Evolution
Old 02-16-2013, 01:01 PM   #1
Never done it and I just bought subs and an amp.. any help with the installation or should I take it to a pro..
Andy714 is offline   Reply With Quote
Old 02-16-2013, 01:34 PM   #2
Mustang_Madness's Avatar
you can do it yourself easily.. you need a power cord from your battery to your amp. so i suggest getting a amp kit at a local sound store. that has most of what you need. preferably one that has a fuse built in about a foot away from the battery. and well move on once i know you have that. you have a box for you subs and all that? what size?
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-16-2013, 03:01 PM   #3
Yes I got the box with 2 12 inch and a 1500watt amp.. I just need the installation kit
Old 02-16-2013, 03:31 PM   #4
TaylorF25's Avatar
The install is cake...just make sure that you run your RCA and remote wires on the opposite side of your car to the power cord.
TaylorF25 is offline   Reply With Quote
Old 02-17-2013, 12:00 AM   #5
curtin1991's Avatar
Send a message via ICQ to curtin1991
Also if you have the stock radio you will need a line out put converter to run a amp . They are cheap on eBay .
Corey
curtin1991 is offline   Reply With Quote
Old 02-17-2013, 03:43 PM   #6
BeachMonkey100's Avatar
I would advise to get some premium 4gauge power wire (not from walmart) and at least a 100-125ANL fuse to run inline from the battery to the amp. The closer the fuse is to the battery the better, no further than 18" from the battery though.
BeachMonkey100 is offline   Reply With Quote
Old 02-17-2013, 09:39 PM   #7
I'd advise you take it somewhere so you don't fry your car lol just one of those areas that needs to be done right just my 2 cents shouldn't cost much
Moto111 is offline   Reply With Quote
Old 02-17-2013, 09:55 PM   #8
That works too, I grew up doing audio so it's easy lol.
2006 Mustang GT Premium Satin Silver Metallic | 5 Speed Manual | Hurst Short Shifter | K&N CAI | JSR Strut Brace, FLCA Brace, Rear Shock Tower Brace | Flowmaster Axle Backs | Ford K Springs | JM Trackbar | 93 Bama Performance Tune
Old 02-17-2013, 10:20 PM   #9
curtin1991's Avatar
+1 not but a few wires
Corey
Old 02-17-2013, 10:31 PM   #10
That's right, still a little bit more to it but all in all it's pretty simple. soon here I'm going to take my gt I just got and do my big 3 and then run all my stuff for the system. I might do a write up to help anyone who's looking to do it.
Old 02-18-2013, 02:51 AM   #11
Jimmy84's Avatar
Region: Nebraska
Big 3? And I am as well thinking about putting my old system in my new 04 gt .. 2 12 alpine type -r with a JL amp but my box is way too big .. Should I downgrade or customize a box ? .. And I don't want everything on my car to rattle anyway to Provent that .. I know dynamat is good but .. Idk and how do I get my faceplate and shift plate to come out without breaking it ugh
Jimmy84 is offline   Reply With Quote
Old 02-18-2013, 06:37 AM   #12
Big 3 referring to a wire upgrade in the engine compartment. (Block to ground, chassis to ground, positive to alternator) the bigger the wire the less resistance therefor giving you a .2-.8 more volts on the battery while running. YouTube it and google it you'll see. Is it necessary for you and me? Probably not, but when I have all the stuff to do it from my previous car then so be it.
And is your box now ported or sealed? I would only make a new box per the cubic feet needed for it to sound right. And for dampening I would use dynamat, second skin, lizard skin, all of them work pretty well. Whatever really you can afford
Old 02-24-2013, 03:47 PM   #13
Jimmy84's Avatar
Region: Nebraska
My box is ported in middle and they wouldn't fit through the trunk maybe backseat but I highly doubt it and yeah that's my problem air space good enough for the subs alpine type R and for dynamat ya I just don't want the Interior to fall apart
Old 02-26-2013, 09:10 PM   #14
Xaperez100's Avatar
Just take out the spare and remove the carpeting and work it in there through the trunk. That's what I did and I had 2 12"'s in a ported box as well but now I have one 12" jl w7 and it hit louder than my 2 12's I had. Lol
Xaperez100 is offline   Reply With Quote
Old 02-26-2013, 10:13 PM   #15
curtin1991's Avatar
I had to remove my carpet and tire kit as well then wedge it back up under the box once situated also . To instal my 15in p3
Corey
Old 02-26-2013, 10:16 PM   #16
Xaperez100's Avatar
Old 02-26-2013, 10:39 PM   #17
curtin1991's Avatar
Lol
"It ain't rite if it ain't tight "
Ill have to get you a pic of min
Corey
Old 02-26-2013, 10:53 PM   #18
Sbales88's Avatar
I think its an easy job, i put a whole new system in my car head unit door speakers rear speakers and two 10 inch subs with a 1200 watt amp with no problems. Sounds great
Sbales88 is offline   Reply With Quote
Old 02-26-2013, 11:07 PM   #19
Xaperez100's Avatar
Yeah it's easy to install but with the box we had I'm guessing his was bigger for the 15 it's a little difficult putting it inside the trunk lol
Old 02-26-2013, 11:13 PM   #20
Sbales88's Avatar
I bet it was! tens were the biggest i could fit in my trunk with slotted boxes and with the spare tire. Puttin a 15 in would be interesting lol
Old 02-27-2013, 08:33 AM   #21
curtin1991's Avatar
I had to take out the plastic trim in the trunk also to slide it in . Then reinstall it with box in place . PITA
Corey
Old 02-28-2013, 12:50 PM   #22
This was in a customers 07 stang
Two 10 in L7's
The box was quite a ugly thing. It had been built in the trunk. It is going to need a sawzall to get it out. It had a ok beauty panel. But it sounded good. Way to much base for only having the front speakers amped, but the customer did not want a 4 channel amp and he liked the way it sounded so that's all that matters.
Tec_ is offline   Reply With Quote
Old 02-28-2013, 01:27 PM   #23
curtin1991's Avatar
Looks good. So do you do audio on the side or is it you're full time business ?
Corey
Old 02-28-2013, 02:14 PM   #24
On the side. It's the hobby job. My full time gig is in the test and measurement electronics field. It cost to much to do to my car all the time so why not get paid to do it for others.
……and to get a discount on stuff
Old 02-28-2013, 08:57 PM   #25
curtin1991's Avatar
True . Same here
Corey
Old 03-06-2013, 07:59 AM   #26
04_sonicblue's Avatar
2-10's should be plenty I just ordered my door speakers fosgate t1's, and 2 10's kicker cvt's I plan on getting the fiberglassed in the back trunk corners
04_sonicblue is offline   Reply With Quote
Old 03-25-2013, 09:31 AM   #27
syas07's Avatar
Send a message via Yahoo to syas07
Is there any splicing involved with the wires? Dealership is blaming my subs for my headlights shorting out. Saying if it was spliced with a harness it's causing a short circuit.
syas07 is offline   Reply With Quote
Old 03-25-2013, 12:27 PM   #28
You only splice in to factory wiring if your using subs with the factory radio. If your headlights don't work after your subs were installed I'm betting who ever did the install tried to grab the 12v turn on from some where they shouldn't have.
06:09 PM
