Not picking up Radio Stations. - Mustang Evolution
Old 05-02-2013, 07:57 PM   #1
rangerbert's Avatar
I have the Shaker 500 radio. Like everyone else I had the error code. Sounds like a cd stuck in it but no cd was in it. After doing a little research I found out that the mechanism needed changed. I found out that if you changed the mechanism that I wouldn't need to have it reprogrammed. So today I changed the mechanism. Everything is working fine except no radio stations won't come in. The antenna is hooked up. Any ideas as to what could be the problem. Thanks in advance.
rangerbert is offline   Reply With Quote
Old 05-06-2013, 02:26 PM   #2
rangerbert's Avatar
Wow. None of you Mustang gurus know how to fix not the not getting any radio stations.
Old 05-06-2013, 03:11 PM   #3
Blogger
99ford's Avatar
By chance did you plug the antenna back into the back of the stereo
Old 05-06-2013, 03:14 PM   #4
NewMtang's Avatar
In defense of all the Mustang Gurus out there, OUR STEREOS WORK JUST FINE!
Old 05-07-2013, 08:28 AM   #5
kickerofdoom's Avatar
I have a custom sound system but check the wire and trace it
Old 05-25-2013, 05:45 AM   #6
rangerbert's Avatar
Well I figured out why I wasn't able to pick up any radio stations. I pulled the radio back out last night. Look at the spot where the antenna plugs into the back of the radio. There's a fine wire that was bent. Straightened it out then plugged the antenna back up. I didn't know about that fine wire.
» Members Mustangs
Mustang
UB2PED
SGM
BigCiv
Add your Mustang
04:33 AM
