Speaker install specs - Mustang Evolution
Old 05-20-2013, 08:51 AM   #1
Hey everyone. Having a tough time finding specific installation specs for my 2014 mustang.
Here's what I've gathered so far... Can someone please confirm?
1) door speakers consist of a 5.25" plus tweeter with 8" subs/mid-bass in the lower quadrant.
2) Rears are the same 5.25" config as doors
What I'd still like to know is how much depth I have to play with in the doors.
Thanks a ton!
Lem
Lemonart is offline   Reply With Quote
Old 05-24-2013, 08:25 AM   #2
GE3G's Avatar
I think the doors are 5x7 ad 6x8 in the rear
GE3G is offline   Reply With Quote
Old 05-24-2013, 09:32 AM   #3
I keep hearing those measurements. But didn't they change to component 5.25" plus tweet?
Lem
Old 05-25-2013, 08:29 PM   #4
joedelpen's Avatar
Region: Nevada
5x7 6x8 both sizes fit it most speaker mount areas. There very close in size even though there different. In the door the space should be a issue with any replacement speaker you through in there. The sub I personally have it unplugged and put JL audio in the truck. Got a tread to check it out. Also they make low profile subs by a few company's like JL for instance but you'll need the cu ft vol. space witch I doubt you find there. So... What are you looking to do??
---------- Post added at 07:27 PM ---------- Previous post was at 07:26 PM ----------
Thanks a ton!
Lem
Should be over a few inches at least as far as depth goes with the door speakers hi-mids, with 5x7 6x8 mounts. And tweeters you can put anywhere you can fit them and they look clean.
---------- Post added at 07:29 PM ---------- Previous post was at 07:27 PM ----------
Another thing is open the door panel up and look and measure. That's the best way to be sure. You can find tons of instruction how to take off the panel without braking it...
POLICE PROTECT AND SERVE THIER WALLETS
joedelpen is offline   Reply With Quote
Old 05-25-2013, 10:24 PM   #5
My main goal is to simply replace the factory speakers with Focals. Probably throw in a JL XD amp.
Just want to augment what's there. Stealth install. No big subs needed nor wanted. The 8's in the doors with a nice amp will be more than fine on the low end .
Lem
Old 05-25-2013, 10:32 PM   #6
joedelpen's Avatar
Region: Nevada
Lem
I'm thinking of getting focals for my 05. They should fit fine. I've changed speakers out of many of my vehicle never had an issue. Good luck to you
12:18 AM
