Touchscreen on 02 - Mustang Evolution
Old 06-06-2013, 07:22 PM   #1
sam62893's Avatar
Touchscreen on 02
So I bought a touchscreen unit for my car and thought, maybe I could install it myself. If worse comes to worse, I have a friend who can hook it up for me. Any tips? It's an 02 v6 with the factory radio and harness.
Old 06-06-2013, 07:27 PM   #2
zinc_yellow's Avatar
Region: New Mexico
It's pretty simple I installed my jvc double din. You will need the mounting hardware and a wiring harness
zinc_yellow is offline   Reply With Quote
Old 06-06-2013, 07:32 PM   #3
sam62893's Avatar
Where can I get the wiring harness. And about how much did it run you?
Old 06-06-2013, 08:29 PM   #4
Any local audio shop or best buy with a install bay will have the kit and harness all you do is unplug the factory one match the colors on the harness crimp or solder do not twist and tape and you pop it all back together. It is quite easy.
Tec_ is offline   Reply With Quote
Old 06-06-2013, 08:50 PM   #5
sam62893's Avatar
What kit would I need? I was going to crimp wires directly but I can't be sure of any of the diagrams I find online. I'm sticking to buying the harness instead. And is this a problem? It won't fit haha
Old 06-06-2013, 09:05 PM   #6
It needs a dash kit! And for the love of god don't cut the factory harness off! Buy the parts and it will pop right in!
Old 06-06-2013, 09:13 PM   #7
sam62893's Avatar
Heck no! No cutting for me hahah previous owner did that to my other stang and it's a pain to work with! I took the outer metal skin off the unit. It won't affect it right? It just won't fit into the radio bezel with it on and now it fits fine. What dash kit should I get? I'm kinda stumped on that. Just find one that would fit my ford harness?
Old 06-06-2013, 09:47 PM   #8
That cage is for mounting in a RV or something you would have to cut a hole for. The kit will hold the radio it is a metra 95-5026 the harness is a metra 70-1771 for a non amped ford and a metra 70-5519 for a amped radio. Any radio shop or install bay will have the parts and can look them up to double check. But I found that info on metra online.
Old 06-06-2013, 09:57 PM   #9
sam62893's Avatar
Okay cool. Thanks took it off. Ill look those up and get one ASAP. They wanted to bend me over $120 for install haha seems simple you saved me a ton of cash. Ill post when I get it installed
Old 06-06-2013, 11:07 PM   #10
Region: New Mexico
You don't slide the radio through the plastic trim.. It Mounts into the slot on the car then the trim fits over it
Old 06-06-2013, 11:25 PM   #11
sam62893's Avatar
There's a black trim that goes around the screen itself and it will not fit if I put the bezel on. But I'll figure it out after I get my dash kit and harness
Old 06-07-2013, 06:08 AM   #12
The dash kit will have the trim ring that will fill up any empty space between the deck and your cars trim.
Old 06-07-2013, 06:24 PM   #13
sam62893's Avatar
Okay so I'm sure this isn't the right harness. I was told they were sure because it says all ford '85-'04. Idiots. Going to have to wait till tomorrow to get the right harness or just order it online
ID:	112715   Click image for larger version
Old 06-07-2013, 06:30 PM   #14
Yup that's for older decks
Old 06-07-2013, 08:02 PM   #15
sam62893's Avatar
Yeah, I only got it excuse I got confused with my '97 and my '02. Oh well. Ill get the correct one
Old 06-08-2013, 01:48 AM   #16
sam62893's Avatar
Can't believe I found the harness at autozone! Fits perfect and got it connected. All I need now is the dash kit and I'm set! I fell in love with it
Old 06-08-2013, 02:33 AM   #17
Venomouz831's Avatar
Looks good
)02 Gt, Founder of WE2G
05:58 PM
