mach 460 system help - Mustang Evolution
Old 07-27-2013, 06:32 PM   #1
Mustanglx92's Avatar
I wanna install a aftermarket amp in my 99 mustang i have the stock head unit can anyone help
Mustanglx92 is offline   Reply With Quote
Old 07-31-2013, 10:13 AM   #2
You'll just need a 4 Chanel Line out put converter to get a low level signal to your amp. Then run new speaker wire to your speakers or to your factory wiring and re use that.
For a novice you may have some trouble and it may take you 4-8 hours but at a shop you would be looking at around $200 in labor and 2-3 hours.
Tec_ is offline   Reply With Quote
Old 07-31-2013, 07:06 PM   #3
95Ponyboy's Avatar
What I did was unplug my factory amps and ran 2 separate amps for my mid and lows, if your speakers are still factory go head and remove those while you are at it.
95Ponyboy is offline   Reply With Quote
Old 08-03-2013, 06:59 PM   #4
What if I wanna keep the amps an add the aftermarket and do you knw where I would connect the line output converter?
Old 08-09-2013, 02:26 AM   #5
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
Just saying it be wise to get a aftermarket stereo. Everything will be easier, not cheaper but better
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 08-11-2013, 06:14 PM   #6
95Ponyboy's Avatar
Replace the H U it will be much simpler then being a beginner, sorry I have never bothered to use a stock h u with any system I had everything was after market.
---------- Post added at 07:14 PM ---------- Previous post was at 07:12 PM ----------
I wouldn't keep the amps especially with anything with serious wattage get an after market amp(s)
Old 08-13-2013, 08:17 PM   #7
Roguestang's Avatar
The stock 460 system runs on 3 amps. No aftermarket systems use it. They are all 1, 2, or 4 amps for example. So using anything but 460 amps or speakers in a 460 system may work for a while, until something fries. I had an aftermarket head unit hooked up with an amp and 10" sub working straight off it, separate from the 460 system. Worked for quite awhile, but eventually it fried the whole system and had to replace everything. The stock system sounds decent, but it still lacks what the aftermarket can provide. Just replace it it you want it that bad, IMO.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
06:39 AM
