Subwoofer and Amp Installation Help - Mustang Evolution
Old 08-28-2013, 07:08 PM   #1
I am completely lost when it comes to car audio systems. I recently bought 2 12' jl audio subs and a jl amp. I also have a wiring kit. Other then this, my car audio system is completly stock.
Is there anything else i need to buy?
Does the Radio have the RCA lines?
Is it a hard install?
MikeCross is offline   Reply With Quote
Old 08-29-2013, 01:10 AM   #2
samuelsmith's Avatar
You need this.
NEW Boss B65N High Level TO LOW Level Converter RCA Input Sensitivity Control | eBay
^ connect at rear speakers.
I recommend the ground wire to be less than 12".
Connect the remote wire to a un-constant power. When the ignition comes on, then you have power.
The power needs a inline fuse up front a few inches from the battery.
The rest should be self explanatory.
+No need to pull the radio out
Great choice JL!
Does the amp have a built in crossover?
Old 08-29-2013, 05:28 AM   #3
Thanks man i appreciate it. And your positive i need this? is it so that I can hook up the RCA cables to my radio?
Old 08-29-2013, 07:21 AM   #4
Knooper3's Avatar
Do you have the shaker or the stock unit?
Knooper3 is offline   Reply With Quote
Old 08-29-2013, 08:22 AM   #5
either way ^ neither one comes with RCA hookups right?
Old 08-29-2013, 08:29 AM   #6
Knooper3's Avatar
Well, i know for sure that the shaker doesn't but you can improvise by using the speaker output of the shaker and Hi imput of most amps.
Here's a diagram of the shaker's wiring:
http://farm6.staticflickr.com/5088/5...b3fb50fd_o.jpg
Hope it helps
Old 08-29-2013, 08:34 AM   #7
that's great info ^
if I where him id just get a nice aftermarket double din if I had the cash
Old 08-29-2013, 08:40 AM   #8
Knooper3's Avatar
that's great info ^
hihi so would i, with some rear view camera but the shaker does it's job and my neighbours agree
Old 08-29-2013, 09:18 AM   #9
yeah shaker 500 is all ive got
the shaker 1000 was nice in my friends ride!!
I unhooked my shaker 500 tho and im just
running a single 12 in the trunk now tho
Old 08-29-2013, 09:20 AM   #10
llvllanifest's Avatar
I would go with a single Orion hcca sub and you'll be in good shape, that's what I'm running
llvllanifest is offline   Reply With Quote
Old 08-29-2013, 09:21 AM   #11
Knooper3's Avatar
I have the shaker 500 too. why did you unhook it? I've heard that it does drain the battery and this happens pretty often to me but i've got other mods to do first
Old 08-29-2013, 09:25 AM   #12
because my radio only has 2 rca jacks(ones front & others sub) ive got my sub on sub and when I tried to put shakers on front I cant turn them down enough to sound good so I just took fuse out for their amp for now
Old 08-29-2013, 10:16 AM   #13
Knooper3's Avatar
Maybe you'll find a decent priced shaker 1000 on ebay. that one has a good woofer management and the front and rear speakers are rated the same as i recall so it should be bolt-on
Old 08-29-2013, 10:29 AM   #14
im good with current set up! spent probably half as much as someone wants for a shaker 1000
Old 08-29-2013, 10:58 AM   #15
Knooper3's Avatar
ah, i tought there was an issue with this one. very nice then
Old 08-29-2013, 10:59 AM   #16
ive got no audio issues!! mental issues are another story!, thanks tho
Old 08-29-2013, 01:53 PM   #17
Orion great choice! I had old school 225 and 250 red cheater amps. Along with 4 duel voice coil 12s. The amp ran a 1/2 ohm
and was so hot you could cook a egg on it. Good competition stuff.
Old 08-29-2013, 07:04 PM   #18
qccoles's Avatar
GREAT choice of subs/amp.
In my car, I have 2 amps, 2 12's, double din LCD, and a rear view camera installed.
Tomorrow I can tell you exactly what wires I have ran, just so I don't leave anything out.
You need a ****load of speaker wire if you're planning on running an amp for highs, and I don't think power wire has been mentioned. You should go buy power wire that is at least cars length.
qccoles is offline   Reply With Quote
Old 09-07-2013, 09:47 AM   #19
A sub makes all the difference in the world. Check out this box its cheaper then the JL audio and Kicker set up, and it will fit somthin as big as Rockford Fosgate t2 or Memphis MoJO in it!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=221279116960
Patrick10mustan is offline   Reply With Quote
Old 09-07-2013, 10:05 AM   #20
Loc: Austin,TX
Please review forum rules before posting.
Moved.
03:11 AM
