Stereo install help - Mustang Evolution
Old 09-06-2013, 09:20 AM   #1
MVP u eNVy ME's Avatar
Stereo install help
Do I need these two wires if I don't have an amp? If so where do they even go?
MVP u eNVy ME is offline   Reply With Quote
Old 09-06-2013, 09:20 AM   #2
The left one is a 12v to 5v converter
Old 09-06-2013, 09:27 AM   #3
does your car have a shaker 500/1000
Old 09-06-2013, 09:31 AM   #4
Yeah 500
Old 09-06-2013, 09:34 AM   #5
if you want to use the stock subs n the doors then im pretty sure you've gotta use the wire with the red and white rca & the other wires on it are remote wires I think. as far as the one in your hand idk what that is :\ sorry
Old 09-06-2013, 09:40 AM   #6
The ones with the RCA cables have two amp turn on wires. The other is a 12v to 5v converter
Old 09-06-2013, 09:50 AM   #7
I think theres multiple amp turn on wires incase you have the shaker 1000. one turn on for door subs and one for trunk subs(shaker 1000). I think the 12v - 5v keeps the subs from popping everytime you turn the radio on. I remember when I hooked mine up I had to put a resistor on the amp wire to keep mine from doing what im pretty sure that wire is that you have maybe?
Old 09-06-2013, 09:59 AM   #8
So the thing is the ford factory amps turn on with a 5 volt signal not a 12 volt signal. Turning the factory amp on with a 12v signal will result in a loud "POP" from your speakers. So in order to turn your amp with out the "POP" you need to ground the black wire of the regulator attach the remote turn on from your radio to the input side of the regulator and attach the output side to the amp turn on of your wiring harness.
Tec_ is offline   Reply With Quote
Old 09-06-2013, 09:59 AM   #9
Do you know where I connect it to? The amp remote off of the stereos harness?
Old 09-06-2013, 10:13 AM   #10
There should have been at least two harnesses you unplugged from your factory radio, possibly three. It's very straightforward what plugs into what, they are all keyed so they will only plug into the corresponding plug.
Old 09-06-2013, 10:18 AM   #11
nice save tec!!
Old 09-06-2013, 11:31 AM   #12
Originally Posted by silverskoundrel
nice save tec!!
Meh I hope it helped. I work doing car audio part time and fords are actually quite easy even if they have stupid speaker sizes. Im just not sure if I'm always abel to type out what I want to explain.
Old 09-06-2013, 11:49 AM   #13
I had a feeling that's what it was for but you nailed it as far as im concerned lol you broke it down real well
08:28 PM
