2 10's with Mach 460 - Mustang Evolution
Old 09-25-2013, 12:11 AM   #1
BlackSmoke02's Avatar
I have a box with 2 10s and was wondering how I can hook them up to the rear Mach 460 system. I was told once I can run power straight from the above rear dash speakers to the subs but something sounds wrong in that. Any advice would help
BlackSmoke02 is offline   Reply With Quote
Old 09-25-2013, 01:13 AM   #2
kickerofdoom's Avatar
Won't work there a extra line to add amps and a sub but you can't hook up to the Mach 460 directly cause the amps power your speaker
Old 09-25-2013, 01:33 AM   #3
Would taking the wires that go to speakers and putting them to the subs work?
Old 09-25-2013, 02:10 AM   #4
Depends on what kind of subs you have but I would say no. The best way is what I did years ago CD player then change out your speakers and add a amp for speakers. Then get a amp for the sounds and your good to go. Also I do remember there is a by pass wire for subs but you still need a amp.
Old 09-26-2013, 04:43 PM   #5
What would be the easiest way to connect them just from the rear? I have a amp on top of the two small mach460 ones that I can connect to the new subs. And the subs are just the one where you slide the positive and negative wires into there little slots and there good
07:12 PM
