2011 Mustang V6 needs power! - Mustang Evolution
Old 10-22-2013, 02:13 AM   #1
Hustler1593's Avatar
Hi, I have two 10" Rockford Fosgate p3s kicker component speakers with a memphis amp for highs and a memphis monoblock. When my bass hits my lights dim and my rpm starts to flutter. What can I do to stop this? Some say a capacitor does not work..some say get a 2nd battery..some say upgrade your alternator..can someone please give me a solution. Thank you in advance.
Hustler1593 is offline   Reply With Quote
Old 10-22-2013, 06:38 AM   #2
So the battery under the hood of your car is only there to start your car. Once it's running all of your electrical is powered by your alternator.
So if your putting enough pull on the system to dim the lights I'm going to say go with a high amperage alternator and upgrade the big 3 (the lines in your charging/power system) when you do. Positive line from alt to bat, ground from bat to chassis, and the engine block to chassis. Shouldn't use anything less than 4ga wire for that.
A cap just provides a reservoir for your amp to grab power from. It dose not change the fact that your alternator still isn't powerful enough to power your system.
As for batteries you can spend money on a nice one under the hood and that can help out but unless your alternator is up to snuff adding a second one isn't going to do much.
Tec_ is offline   Reply With Quote
Old 10-22-2013, 07:22 AM   #3
Project Pony's Avatar
Agreed. Adding a second battery will only hurt unless you upgrade your alternator. Without increasing your amperage a second battery will only strain your charging system further, as your alt is trying to run the electrics, charge both batteries and power your stereo. A cap is a band aid for the real problem and a waste of money. Upgrade the alternator and crank up the volume.
[SIGPIC][/SIGPIC]
Old 10-24-2013, 11:07 PM   #4
Thanks guys! Where can I find a upgraded alternator? I tried looking for one and couldnt find one.
Old 10-25-2013, 09:36 AM   #5
American muscle has some I believe. There are also companies that build high output ones for car audio purposes. If you google high output alternator you should be able to find something.
But make sure you upgrade your big 3 or you'll choke out the flow of all the juice.
Old 10-25-2013, 03:44 PM   #6
What is the RMS power ratings for your amps? (Not max power, but the nominal rating)
Also, what wattage and how many fuses in each amp? Do your have any other aftermarket electronics in your mustang?
[SIGPIC][/SIGPIC]
Old 10-25-2013, 04:36 PM   #7
Originally Posted by Project Pony View Post
What is the RMS power ratings for your amps? (Not max power, but the nominal rating) Also, what wattage and how many fuses in each amp? Do your have any other aftermarket electronics in your mustang?
The P3s are 500w rms so I'm guessing he's running at least 1000w amp.
He could probably get away with only doing the big 3 and holding off on the alt for the moment.
01:00 AM
