Quick Radio Wire Question - Mustang Evolution
Old 11-13-2013, 11:17 PM   #1
clflorida's Avatar
Region: Arkansas
Hey guys! I have a blue negative power antenna wire from the car. And on the radio I have a light blue/yellow steering remote control wire, blue/white power control wire, brown mute control wire, and a blue antenna control wire. It seems like the blue one but the manuel says not used. Do I just forget about the blue wire coming from the car?? When I unhooked the last radio it was just sitting there not attached to anything.
---------- Post added at 12:17 AM ---------- Previous post was at 12:14 AM ----------
Also do I need to unhook the battery before I connect the rest? Ground, ignition, battery?
clflorida is offline   Reply With Quote
Old 11-13-2013, 11:21 PM   #2
andregayola's Avatar
Originally Posted by clflorida View Post
Hey guys! I have a blue negative power antenna wire from the car. And on the radio I have a light blue/yellow steering remote control wire, blue/white power control wire, brown mute control wire, and a blue antenna control wire. It seems like the blue one but the manuel says not used. Do I just forget about the blue wire coming from the car?? When I unhooked the last radio it was just sitting there not attached to anything. ---------- Post added at 12:17 AM ---------- Previous post was at 12:14 AM ---------- Also do I need to unhook the battery before I connect the rest? Ground, ignition, battery?
Not sure because I don't really do electronics but disconnecting batterie is my first choice always
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 11-14-2013, 06:08 AM   #3
mystang50's Avatar
always a good idea to unhook the battery, the neg (black) being you last and first connection when doing so...on the battery
01:56 AM
