Kenwood and Maestro in Mustang! - Mustang Evolution
Old 11-15-2013, 02:58 PM   #1
12V Guy's Avatar
Hi Everyone,
We are pleased to announce the launch of our new Ford Mustang Installation kit (MUS1) and wanted to provide some info about the solution. The kit works in 2010-2014 Mustangs without factory navigation.
To install the complete solution including the dash kit, you need three things:
1. Compatible Kenwood radio - currently any 2013 DNN/DNX double din navigation. These range from $850 for the most basic unit to $1700 for the Android based, connected model. You will also need the SiriusXM SXV200V1 sat radio tuner if you want to add back sat radio. The factory tuner is inside the factory radio you are pulling out.
2. Maestro RR (p/n ADS-MRR): Web programmable interface module that will connect radio to car bus and retain factory steering wheel controls. You can even program 2 radio features per steering wheel button. You can see the product here: http://maestro.idatalink.com/product...product_id/102
3. MUS1 (p/n ADS-KIT-MUS01): Installation kit including dash bezel, customizable button bar, radio mounting brackets, storage pocket with 2 flush mount USB ports and plug and play T-harness to simplify the wiring job. You can see this part here: http://maestro.idatalink.com/accesso...product_id/285
If you want to simulate what happens when you program this solution, you can click here: http://maestro.idatalink.com/weblink/demo/demo-rr
Choose a 2010-2014 Ford Mustang Base from the car selector
Select your steering wheel
Choose a compatible Kenwood radio (you can use DNX890HD for this example)
Choose iDatalink Serial Cable for the Connection Type
Choose the MUS1 in the ACCESSORY Step
Choose the Factory systems you wish to retain (you have to have these to retain them)
Assign your steering wheel buttons as you like and assign shortcuts to the button bar in the kit. BTW, the kit comes with matching button tops for all the choice you can make that you snap on to the bar after you program.
Choose your units - English or Metric
Flash Your Module - simulates programming of module
Download guide to see how the install really works!
Now on to the features:
Climate screen IN THE RADIO! (see attached pic) - Full climate integration right in the radio. When using the MUS1, you also get a button bar with 5 buttons. Three of them can be assigned as shortcuts to climate features you want quick access to. No secondary LCD and radio sits higher in dash.
Gauges screen (see attached pic) - Pick any 5 gauges from a list of custom gauges and add them to a screen in the radio.
Vehicle info screen (see attached pic) - New screen that will show you tire pressure at each tire for the factory TPMS. Also, any open door and battery voltage. In addition, if you get a check engine light, you can see the code and attempt to clear it.
Dedicated iDatalink Port on radio (seee attached pic): You can add Maestro AND install an aftermarket satellite radio tuner at the same time. No more choices. This is a big deal since when you remove the factory radio, your satellite tuner is removed with it. 2012 Kenwood radios did not have this port.
Secondary display - Remains active and will show meta data not only for the Ford sources (Sync, phone, etc) but for the Kenwood sources too! RDS data in tuner, meta data in CD/DVD and iPod/USB screens.
Note: We cannot retain clock as it's inside the radio you take out. Kenwood radio does not tell us the time. We hope they will support it next year.
Hope you all like! Mustang kit began shipping today and you can see it here: http://maestro.idatalink.com/accesso...product_id/285
BTW, Maestro can be used with any radio for basic radio replacement and steering wheel functions but, in order to retain Sync, use the MUS1 and do the rest of what is indicated in the pictures, Maestro must be installed with one of the 2013 Kenwood DNN or DNX Navigation radios. We'd love to work with other radio brands, but there is R&D required and they need to hear from customers that they want these kinds of solutions to make the decision to do it. If you want <<Insert brand here>> radio to work with Maestro, write or post to them and ask them for it.
I will monitor forum for questions, so ask away!
Best,
ID:	136600   Click image for larger version
ID:	136602   Click image for larger version
12V Guy
Automotive Data Solutions, Inc.
Montreal, Canada
12V Guy is offline   Reply With Quote
Old 12-12-2013, 02:01 PM   #2
CHIZ_65's Avatar
Will any of the features not work for us base-model guys? I have no synch, and no radio controls on my steering wheel.
Easier/cheaper for me to do this upgrade?
CHIZ_65 is offline   Reply With Quote
Old 12-12-2013, 03:39 PM   #3
CHIZ_65's Avatar
I guess what I'm asking is....Is the Maestro RR required if you don't have synch, blue tooth, or any steering wheel controls? And am I still limited to ONLY Kenwood if that is the case?
Old 12-12-2013, 06:17 PM   #4
timle8n1's Avatar
The Maestro RR is needed for the climate controls and only Kenwood has support for controlling them in the radio as far I know.
timle8n1 is offline   Reply With Quote
Old 12-12-2013, 06:22 PM   #5
CHIZ_65's Avatar
From what i read on the Maestro page, the RR unit is for retaining steering wheel controls and synch functionality. So, if there are climate contols on some peoples steering wheels, i see what you're saying. But... is the RR unit also required to bridge the gap from the manual/dash climate controls to the Head Unit?
Old 12-12-2013, 06:34 PM   #6
CHIZ_65's Avatar
I just read a conversation a guy had with a Maestro rep on another thread...sorta answers my question...
"You will also need the Maestro RR (ADS-MRR) module in order to get your climate controls, performance gauges, and vehicle info like tire pressure, open doors, check engine codes, etc.. all on your Kenwood touch screen. If you have steering wheel controls, the Maestro RR will also retain those."
Old 02-03-2014, 04:36 PM   #7
12V Guy's Avatar
Corrected Button Bars Available
For details see here:
Maestro Mustang Dash Kit (MUS1) - Corrected Button Bars
12V Guy
Montreal, Canada
06:33 AM
