2013 mustang sub box - Mustang Evolution
Old 01-24-2014, 12:40 PM   #1
austin0324baird's Avatar
Ok! Soooo quick question... Sooo I have a 2013 mustang... And i installed 2 12 inch subs. SSL (sound storm lab) great subs!! 4,000 rms peak for the 2 combined. It's running off of a 1250 watt amp. Not sure the name but it's not like a cheap name. It produces good wattage. Lol anyway! I have just a regular 2 12 sub box. But I have seen stuff on like zenclosures.com that have a perfect fit. So I bought 1! Sucked... Bad... Perfect fit!! But like 1.1 cubic feet and my subs need atleast 2 cu ft to preform decently. My question is... Does anybody have or know where I could possibly get a box that would fit in the back without costing like $150+. Also I can possibly build... Not that experienced but I can give it a try. Thnx for any response! Click image for larger version
Name:	ImageUploadedByMustang Evolution1390592407.426964.jpg
austin0324baird is offline   Reply With Quote
Old 01-27-2014, 03:36 PM   #2
Brandonb2012's Avatar
If the box from zenclosures fit why not use the same specs but make it come out more?
Brandonb2012 is offline   Reply With Quote
Old 01-27-2014, 03:38 PM   #3
When I did, it wouldn't fit... Lol
Old 01-27-2014, 03:53 PM   #4
Ooo ok I see what u mean it wouldn't go in the trunk hahah yeah well, unless you put the last piece on inside the trunk? Or see if you pull the rear seats out what you could fit in?
Old 01-27-2014, 04:00 PM   #5
Nope wouldn't fit even when I put the face of the box separate from the body of it. And no wouldn't fit through the seat part. Haha what about 2 different sub boxes? Like 2 single 12 inch sub boxes
Old 01-27-2014, 04:04 PM   #6
Dang that sucks man lol but yeah you could always do that, I'm having same problem as you I bought a box for a Kicker L7 10 inch that would fit in my car but sadly it's to small I can literally hear the air bouncing of the box ha
Old 01-27-2014, 04:08 PM   #7
I have no clue. Sounds like a box fail. Lol try making Ur own! It's pretty simple and satisfying. I did that in my first car.
Old 01-27-2014, 04:10 PM   #8
Yeah that's what I was going to do build it to slide right in cuz the inside of ours has that little hump inside, but I wanted to build one for two but I hope I don't run into the same problem as you
Old 01-27-2014, 04:13 PM   #9
If u have 10 inch subs. Then nah! U shouldn't. Just google the cu ft Ur subs need to get max power. And do that b4 u do ur subs. And if it doesn't fit, just sell it or somethin. Idk! Haha but u shouldn't have the same problem.
Old 02-03-2014, 02:06 PM   #10
somedopebeats's Avatar
Originally Posted by austin0324baird View Post
Ok! Soooo quick question... Sooo I have a 2013 mustang... And i installed 2 12 inch subs. SSL (sound storm lab) great subs!! 4,000 rms peak for the 2 combined. It's running off of a 1250 watt amp. Not sure the name but it's not like a cheap name. It produces good wattage. Lol anyway! I have just a regular 2 12 sub box. But I have seen stuff on like zenclosures.com that have a perfect fit. So I bought 1! Sucked... Bad... Perfect fit!! But like 1.1 cubic feet and my subs need atleast 2 cu ft to preform decently. My question is... Does anybody have or know where I could possibly get a box that would fit in the back without costing like $150+. Also I can possibly build... Not that experienced but I can give it a try. Thnx for any response! Attachment 145591
Making your own box is easy. Just google your subs, you should be able to find something that says the optimal box dimensions for those subs. Most likely on the manufacturers website or in an owners manual. And youtube how to assemble it! Screw + woodglue and a jigsaw is all you'll need
somedopebeats is offline   Reply With Quote
Old 02-03-2014, 02:13 PM   #11
13BKV6's Avatar
question for the OP or anyone else that installed audio... my 13 is a base with no sync... do ya'll know if a good, decently priced dash kit to install a touch screen?
Current: 2015 GT Premium Performance Package-stock for now
Past: 13 V6, 11 MCA V6, 89 GT, 88 GT, 04 V6
13BKV6 is offline   Reply With Quote
Old 02-03-2014, 02:16 PM   #12
13BKV6's Avatar
I'm also having the same issue finding a good box.. i'll post if/when I find anything
Old 02-03-2014, 02:18 PM   #13
I don't know of any tbh. I seen 1 that relocates it behind the shifter. And that's terrible IMO. But best best is custom make it... Into a double din. Not sure how to help here. Mayb the raxiom navigation on americanmuscle.com
Old 02-03-2014, 02:19 PM   #14
It is very easy! I've done it! But the problem is, with the 2013 and 14's I know that the tail lights come up and make it hard for a normal sized box to fit. Like a normal 2 12 inch sub box. Will not fit. It has to b like tilted or the box designed at an angle.
Old 02-03-2014, 02:24 PM   #15
13BKV6's Avatar
that one says it requires sync.... I still thought about getting it, but at that price I want to be able to use all of the features. I want to install a backup camera anyway so it would be perfect if only I had sync
Old 02-03-2014, 02:25 PM   #16
Or u could do what I've thought of doing maaaany time. An iPad mini dash kit. It looks so cool.
Old 02-03-2014, 03:21 PM   #17
Yea 2 12"s def will not fit lol i had a 12 in a custom box in my '95 and i had to put it in the backseat lol. Go xzibit style and cut out the backseats and add like 10 more subs lol. I dunno what to say tho if ya wanna fit 2 12"s in and have the box sized to spec. Take some measurements, maybe itll fit if you can assemble some of it inside the trunk (pre-cut pieces and jst screw tem togeter inside). I got 2 10's that im deciding what to do with in my '14 base too.
Old 02-03-2014, 03:37 PM   #18
Yea haha delete the rear seats and just make a really good looking fiberglass box with like 4 12's and 2 15's hahaha that'd b pretty cool. But nah haha imma just probably assemble it in the trunk. I was trying to make it like... Perfect fit and clean looking! But that's not the best option i guess. Haha
Old 02-03-2014, 04:15 PM   #19
Yeah that's what I wanted to do like put it all the way flush inside the back of the trunk
Old 02-04-2014, 06:52 AM   #20
Yea... It just makes it so complicated with the gas tank curve and everything. I I may just go the single box for each. And just put them in the corners.
Old 02-04-2014, 07:19 AM   #21
Yeah it pisses me off, we could have a lot more trunk space after you set your subs in there if you could place them all the way back somehow
Old 02-04-2014, 07:51 AM   #22
Exactly right? And it would b like 100x neater and nice looking.
Old 02-04-2014, 07:58 AM   #23
Build a fiberglass box where the spare tire is and set the sub in flush with the floor.
Old 02-04-2014, 08:08 AM   #24
Nah. My mustang is my dd. so a spare would b nice. Plus 2 12's wouldn't fit. Nor have enough air space.
Old 02-04-2014, 08:25 AM   #25
I meant for just one sub lol.
Old 02-04-2014, 09:11 AM   #26
Well... Then the other 1 gets left out... And a waste. Soooo nah. I'll just leave it looking ugly haha!
Old 02-11-2014, 10:18 PM   #27
Sell it for parts
2 12"s will rattle your car into the ground anyways. I got 2 10's in my winter beater mitsu eclipse and theyve rattled everything loose that they possibly could have, im talking parts falling right off. Even cracked my crappy dash :/
Now my exhaust in my stang is all the music i need
2013 mustang
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Please Sticky: 2013 American Muscle Show and Mustang Evolution Meet Info DWC_SmOziLLa AmericanMuscle 101 08-15-2014 06:34 PM
New Steeda Rear X-brace - Keeps rear seats! tj@steeda 2011-2014 Mustang GT 16 06-18-2013 06:32 PM
08:20 AM
