ported 10 inch subwoofer box - Mustang Evolution
Old 01-24-2014, 05:36 PM   #1
I ordered a dual ported 10 box off ebay for my 2000 stang. The width and depth is good but the height is 13 inches. Will it fit through my back seat if I take that bracket thing off thats around back of the seats
tyronekndrck is offline   Reply With Quote
Old 01-25-2014, 10:06 AM   #2
Jaytraeg's Avatar
You would be correct in assuming that. If you remove the entire back seat bracket around the opening to the trunk, you would be able to fit a 13hx29wx34l box in the back. However, if you wanted to just slide it in from the trunk deck opening, then the max height would be 10". It's a little more work, but you can do it. What kind of subs are you throwing in there? XD
Jaytraeg is offline   Reply With Quote
Old 01-25-2014, 06:10 PM   #3
Musmyke's Avatar
I have two ten inch subs and they slide into my trunk easy without removing my seats
Name:	ImageUploadedByMustang Evolution1390698617.268966.jpg
ID:	145761Click image for larger version
Musmyke is offline   Reply With Quote
Old 01-25-2014, 06:17 PM   #4
Jaytraeg's Avatar
Haha, nice subs. Bet they bump.
Old 01-25-2014, 06:36 PM   #5
Musmyke's Avatar
They do bro haha worth the money
Old 01-25-2014, 07:19 PM   #6
Be grateful your not in a convertible cause I can't just take off my back seats and slide them in. I have to shove them in my trunk. I got 2 10s in a sealed box btw
Old 01-25-2014, 07:30 PM   #7
Jaytraeg's Avatar
Actually guys, I hate to take this thread on a different topic, but I will for your sake.
BE CAREFUL WHEN WIRING YOUR AMP, AND GROUND IT TO THE FRAME INSTEAD OF THE BODY. The guy that I bought my stang from had some subs wired up in the trunk, so I kept them in. But because he wired them to the body, what ended up happening was the current arched to the transmission shift cable, which made it seize up and eventually snap. So be careful, please!
Old 01-25-2014, 07:32 PM   #8
I'm kinda slow but where exactly did he ground the amp. I have mine close to the mach amp
Old 01-25-2014, 10:58 PM   #9
Musmyke's Avatar
I have an convertible it's not to bad if you know what your doing, but like I said ten can just slide right into you trunk. If you wiring it your self, I can help cause me and my dad wired mine and it wasn't hard all.
Old 01-26-2014, 08:48 AM   #10
Jaytraeg's Avatar
The guy that I bought mine from had it wired to a bolt that's behind the driver side tail light, under the carpet. I saw it and figured it was a good ground, but apparently not in this model.
Old 01-26-2014, 08:50 AM   #11
Jaytraeg's Avatar
Where did you ground yours? I need to find a new one before I install my new shifter cable. Thanks mate.
Old 01-26-2014, 10:02 AM   #12
Loc: Austin,TX
Please browse the forum as a whole and review the forum rules before starting a new thread.
Moved to audio section.
Old 01-27-2014, 11:12 AM   #13
Musmyke's Avatar
Name:	ImageUploadedByMustang Evolution1390846343.008559.jpg
That's where I have mine
Old 01-27-2014, 11:18 AM   #14
Jaytraeg's Avatar
Yeah, that's about where I had mine. You haven't had any problems w/ your ground?
Old 01-27-2014, 11:27 AM   #15
Musmyke's Avatar
Nope but I have an manual transmission
Old 01-27-2014, 11:38 AM   #16
Jaytraeg's Avatar
Aaah okay.
Old 01-27-2014, 02:07 PM   #17
Attachment 146037
What gauge is that? It looks skinny af
Old 01-28-2014, 05:16 PM   #18
Musmyke's Avatar
What gauge ? It's my trunk
Old 01-28-2014, 05:31 PM   #19
Jaytraeg's Avatar
He meant the gauge of the negative wire.
Old 01-28-2014, 05:36 PM   #20
Musmyke's Avatar
True let me check
2013 mustang sub box austin0324baird Mustang Audio & Video 26 02-11-2014 10:18 PM
Carbon Fiber Subwoofer Box BeachMonkey100 FYI Ads | Recently Listed 3 02-24-2013 12:02 PM
Hit by lightning NM Mustang guy 2011-2014 V6 Mustang 31 09-29-2012 10:16 AM
Sub choice MTilly Mustang Audio & Video 48 06-03-2012 10:11 PM
Need ideas for Fox stereo SleepingStang Mustang Audio & Video 44 09-30-2011 12:09 AM
02:46 AM
