Maestro Mustang Dash Kit (MUS1) - Corrected Button Bars - Mustang Evolution
Old 02-03-2014, 04:34 PM   #1
12V Guy's Avatar
Hi everyone,
Not sure of the best place to post this, so I am hoping people will see it here and respond.
If you have one of the button bars with the incorrect blue LEDs, I have received corrected ones I can send you.
Please send me a PM (do not post here) with your:
Name
Address
Phone
and I will send you one in a bubble envelope via USPS at no charge to you, no questions asked.
We apologize for the issue and strive for 100% happy customers.
Cheers,
12V Guy
12V Guy
Automotive Data Solutions, Inc.
Montreal, Canada
maestro.idatalink.com
12V Guy is offline   Reply With Quote
Old 02-03-2014, 04:37 PM   #2
Brandonb2012's Avatar
Now that's customer service
Brandonb2012 is offline   Reply With Quote
Old 02-03-2014, 04:43 PM   #3
inthemix's Avatar
I just sent you a message thank you very much!
inthemix is offline   Reply With Quote
Old 02-03-2014, 07:17 PM   #4
Capn__Morgan's Avatar
Boom.
Capn__Morgan is offline   Reply With Quote
Old 02-04-2014, 07:20 AM   #5
Originally Posted by 12V Guy View Post
Hi everyone,
Name
Address
Phone
Cheers,
12V Guy
Will the new kits come with the corrected buttons
Old 02-04-2014, 07:28 AM   #6
12V Guy's Avatar
Hi,
First off, let me clarify the issue. Not all kits have button bars with LED's that are the wrong color. So you may get one that is fine.
Second, the parts in the field already (one we sold to our customers already) will stay as they are.
The ones in our stock are being checked 100% and replaced.
We will continue to make replacements available (1 per customer) at no charge as long as needed.
Hope this helps,
12V Guy
Montreal, Canada
Old 02-04-2014, 07:37 AM   #7
Okay and this kit is to use an aftermarket radio like the kenwood?
Old 02-04-2014, 07:40 AM   #8
12V Guy's Avatar
Hi,
Our kit, the MUS1, is for use with compatible radios (currently only Kenwood 2013 DNX/DNN Navigation radios) and the Maestro MRR module. Our kit does not have any screen for HVAC as we do that in the radio screen. If you search this forum, there are lots of install pics and examples you can see.
Our kit is not universal and cannot be used with non-compatible radios as you will have no way to control your HVAC.
Best,
12V Guy
Montreal, Canada
Old 02-04-2014, 07:50 AM   #9
Okay thanks! Where is the best place to order this?
Old 02-04-2014, 07:53 AM   #10
12V Guy's Avatar
Both Crutchfield and Sound of TriState sell it online direct to customers. Both can package it with a compatible radio of your choice.
Cheers,
12V Guy
Montreal, Canada
Old 02-09-2014, 06:20 PM   #11
Got my new part in and already installed. I'm shocked I got it as fast as I did. From California to Maryland in about two days. Part was easy to swap out and does indeed have a different color. Pics attached...Click image for larger version
Name:	ImageUploadedByMustang Evolution1391995205.212158.jpg
ID:	147468Click image for larger version
Name:	ImageUploadedByMustang Evolution1391995224.238310.jpg
ID:	147469Click image for larger version
Name:	ImageUploadedByMustang Evolution1391995235.438234.jpg
Old 02-09-2014, 06:43 PM   #12
12V Guy's Avatar
The lighting should match the color of your steering wheel buttons.
Cheers,
12V Guy
12V Guy
Montreal, Canada
Old 03-20-2014, 09:06 PM   #13
inthemix's Avatar
I got mine dropped in. The color doesn't match the steering wheel but it is better than the darker blue from before. Also, I have been experiencing a humming sound coming from the speakers whenever the lights are turned on. I've double checked all the grounds and have even isolated the orange wire for the dimmer do it doesn't sit next to the other wires but no dice. 12volt...any feedback?
Old 03-21-2014, 06:35 AM   #14
12V Guy's Avatar
Do you have factory amplifier, but you are using aftermarket amp instead?? Sounds like you are powering up the factory amp but not providing any input to it. Usually this is the RCA labeled SUB that is not plugged into the radio.
What year is your car and what stock audio system did it come with?
12V Guy
Montreal, Canada
Old 03-21-2014, 12:17 PM   #15
inthemix's Avatar
You're right. I determined that it was in fact the sub in RCA that was causing the issue. I terminated the plug with a coax and it went away. I could not locate any plug from my factory harness to connect that to. Do all of the cars have this connected or is only some? I do not have the 1000 sound..maybe the 500? It's a 2012..
Old 03-21-2014, 12:32 PM   #16
12V Guy's Avatar
Hi,
Not sure exactly what you are saying. There are three harnesses that can be connected to the car harnesses. 24 PIN main harness, 16 PIN harness - These two are always used. Then there is an 8 pin. If you have a matching plug in the car, you have an amp for subs. In this case, the RCA should need to be plugged into the SUB out of the radio. If it isn't, the OEM sub amp is being turned on, but there is no input to it. If you are not using that amp, but you connected the 8 pin plug to your car, terminating the RCA works fine. Are you running your own subwoofer amp and speaker? If yes, do nothing. If no, plug the RCA into SUB out on radio instead of terminating..
12V Guy
Montreal, Canada
Old 03-21-2014, 02:49 PM   #17
inthemix's Avatar
You know I thought about that just after I reached out to you on this post. I went ahead and took the terminator off and plugged the RCA into the sub in and all is good. Thank you so much for your fast response on this!
Old 03-23-2014, 12:32 PM   #18
PM sent. Thanks!
sdheath is offline   Reply With Quote
Old 05-04-2014, 10:36 PM   #19
Double J's Avatar
LED Swap....Blue to Red
Maestro Mustang Dash Kit (MUS1) - RED LED Light Bar
2010 Black GT. Appearance mods only so far. SS center fog grille, DG Customs side and window scoops, SLP Loudmouth axle backs, Roush center console button, Roush white shift knob and boot, ADS/Maestro RR dash kit w/ Kenwood NAV setup to retain SYNC.
NOTE: OEM grille, mufflers, and 401A shift knob w/boot are for sale if interested. PM me an offer.
Double J is offline   Reply With Quote
Old 03-17-2017, 11:35 PM   #20
salty5.0's Avatar
Sorry to revive this thread but does anyone know if these are still available? I PM'ed 12V Guy then realized he's been inactive since 2015
salty5.0 is offline   Reply With Quote
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
01:05 AM
