Mach 460 issues - Mustang Evolution
Old 02-04-2014, 03:49 PM   #1
Mach 460 issues
i recently installed new subwoofers into my 02 Mustang. Removed the rear amp rack and installed a pioneer double din. I got a defective subwoofer so i sent it back and just got a new one. I have the system disconnected since the first day due to the faulty sub.
Well i just got a true 4 gauge to replace the crappy 8 gauge that came with the kit.
So i have been listening to the pioneer with just the tweeters and it sounds horrible.
I basically have to turn the volume high to hear anything and if i listen to anything with some decent bass the tweeters crackle, not sure why the tweeters would try and play bass?
Anyways can i use the driver side mach 460 amp to just power the front stock speakers for now? Along with my amp and subs?
I need to save some money to get some full components.
Apex Predator is offline   Reply With Quote
Old 02-04-2014, 04:19 PM   #2
There are 3 amplifiers in the Mach system. The front amp (under the head unit) powers the tweeters, AND, sends the signal to the two rear amps which power the sub woofers on each, respective, side of the car.
So to answer your question, no, I don't think that you should use one of those amps to power the tweeters... if that's what you mean by "stock front speakers".
Old 02-04-2014, 06:03 PM   #3
Question
I believe only the 00 and down cars had an amp under the headunit. 01+ ford removed it.
I believe i have a plan and the source of my problem. When i put in the headunit i also installed the metra kit to keep my stock system. Which of course is not working because i removed the stock amps.
The plan is to remkoe the rear headrest and take the amps and speakers out of the rack and relocate them to the head rest. There are already pre cuts for them there. Plug em in and install the system and there we go problem solved.
Bypassing mach 460 amps vinnygt Mustang Audio & Video 30 02-09-2012 10:45 PM
By-passing mach 460 amps vinnygt Mustang Audio & Video 0 01-30-2012 06:48 PM
Mach 460 bass issue 98GtTurbo Mustang Audio & Video 15 11-29-2011 02:11 PM
mach 460 wiring question... Black_Sunshine Mustang Audio & Video 1 11-27-2011 05:06 AM
Just bought Mach 460 Amp/speaker box... 1 problem though' Black_Sunshine Pre-2005 V6 Mustang 0 10-16-2011 05:42 PM
09:51 AM
