i am wanting to upgrade the mach 460 - Mustang Evolution
Old 12-03-2003, 04:20 PM   #1
01mineralgrey6's Avatar
I have the mach 460 sounds good, but i want to upgrade with out tearing everything out and spending a whole buncha money.....I was wondering if there is a diagram of how the amps run each speaker, if its possible to replace the speakers with any kind, and the wiring diagram if someone has it.
Thank you in advance
-Tony
'99 cobra 'vert
Old 12-03-2003, 09:34 PM   #2
I am still looking for something to help you out on this. i dont have the mach 460 so I cant tell you off the top of my head.
Old 12-04-2003, 11:07 AM   #3
Thanks for looking, I don't have a clue where to start looking.mabye crutchfield might be able to tell me something? ill check there.
-Tony
'99 cobra 'vert
Old 12-05-2003, 02:04 AM   #4
Send a message via AIM to DropTop_Stang
vert or coupe?
-Brian
Feel free to hit me up for questions or chat at AIM: LostMe 03
Keeping my car.
DropTop_Stang is offline   Reply With Quote
Old 12-05-2003, 07:05 PM   #5
coupe. It dosen't specify at crutchfield about anything special. so i guess it just plugs in like any other speaker?
-Tony
'99 cobra 'vert
Old 12-05-2003, 08:10 PM   #6
well, no. It's designed by *****es from hell. You can't just pull and plug. The tweeters/mids and the mid/woofers are getting seperate signals. You will have to rewire and probably want to just pull everything out and start from scratch. It's what I'm doing. But you said you really don't want to so basically you need to pull out the mach amps, reroute some of the exisiting wire from a new amp, and then throw in a component system. Check out Infinity, JBL, JL, Kicker and polk.
-Brian
Keeping my car.
Old 12-05-2003, 09:35 PM   #7
What I would do is yank out all the amps and get you a headunit and use the harness to give the headunit power but run your own speaker wires to the speaker. Get what I am saying?
Or new headunit and get a amp to power your speakers and run the speaker cable from amp to new speakers
Old 12-05-2003, 10:45 PM   #8
Dom
Dom's Avatar
Send a message via AIM to Dom
You know what, the dealer might be able to install all the **** for you. Costly, yea. But, it might sve you a little trouble.
Old 12-06-2003, 02:36 AM   #9
it's about 200-250 for a good install. new amp, 4 new sets of speakers. run brand new wire.
-Brian
Keeping my car.
Old 12-06-2003, 04:11 PM   #10
Thanks for all the info....anyone by anychance know how much to add on to the system to make it the mach 1000?
-Tony
'99 cobra 'vert
Old 12-06-2003, 05:14 PM   #11
Monkey's Avatar
to upgrade the mach460, you have to tear it all out. i was told this by 3 different car audio places. adding a sub is easy, but upgradign speakers and all that is hell.
to upgrade to mach 1000, you need new headunit, the subs, the amps, basically like going from stock system to mach 460. its totally different.
Old 12-06-2003, 05:20 PM   #12
you don't have to rip it all out, it's just easier than trying to reuse what's allready in place.
-Brian
Keeping my car.
Old 12-06-2003, 07:38 PM   #13
basically the best way is to rip it all out and start from scratch
Old 12-07-2003, 01:15 AM   #14
and in the process send me money. Sending me money always helps.
-Brian
Keeping my car.
Old 12-07-2003, 03:39 PM   #15
Thank you all for the information, I might just add a sub, i ran across how to do that at mustangwolrd.com. THanks again!!
-Tony
'99 cobra 'vert
Wanting to Upgrade Mustang OIF2009Mustang Pre-2005 V6 Mustang 10 05-24-2009 12:23 PM
mach 460 charkelly9 Mustang Parts for Sale and Wanted 5 06-15-2005 11:55 PM
Mach 460 megax29 Mustang Audio & Video 6 09-08-2004 02:25 PM
mach 460 Warfire80 Mustang Audio & Video 15 03-03-2004 09:34 AM
Mach 460 starboarder2004 Mustang Audio & Video 19 01-20-2004 09:23 PM
05:06 AM
