Mach Audio System - Mustang Evolution
Old 02-28-2014, 10:38 PM   #1
XSlashDashX's Avatar
Mach Audio System
Reading around on Google, If I replace my "woofer speakers" 6x8 with these would it work?
Amazon.com: JBL GTO8608C 6-Inch x 8-Inch/5-Inch x 7-Inch 2-Way Component System: Car Electronics
I know the amps sends different signal to the tweeters and the woofers. As long as I keep component it should work.
Edited: Saw the JBL's were 2 ohms. Don't think they will work will they? Looking into these and they are 4 ohms.
http://www.amazon.com/Kicker-40CSS68.../dp/B00BGRMD4C
Old 03-01-2014, 05:07 PM   #2
610swolf's Avatar
I have these kickers in mine, minus the amps. Sounds good with my Kenwood deck. A tip though. If you know anybody that works for best buy see if they'll get these for you with their discount. My sister got me two sets of these speakers for less than the price of one.
Sent from my Nexus 7 using Mustang Evolution mobile app
610swolf is offline   Reply With Quote
Old 03-02-2014, 02:26 PM   #3
So I can swap the 6x8 without messing with the whole mach system?
Old 03-07-2014, 05:55 PM   #4
610swolf's Avatar
Sorry for the late reply. Yes you can replace your speakers and everything else be fine.
Old 03-08-2014, 11:17 AM   #5
Sweet thanks.
Old 03-08-2014, 11:18 PM   #6
Region: Utah
I am needing to replace my factory Mach 1000 stereo system. Looking for a wiring diagram for this system.
Bryguyslc is offline   Reply With Quote
Old 03-08-2014, 11:18 PM   #7
I'll take your 1000 rack and subwoofers.
Old 03-08-2014, 11:34 PM   #8
Region: Utah
Thank you but I plan on using all of the stock components except the deck. That is why I am in need of a wiring diagram.
Old 03-08-2014, 11:34 PM   #9
Darn lol
Old 03-09-2014, 08:45 PM   #10
SonicBlue's Avatar
Bryguyslc - Mach 1000 wiring diagrams, as requested. More info here.
BUT, if you're just swapping out the head unit, Crutchfield will give you all you need - without having to do anything with your wiring. Check this out.
XSlashDashX - have you seen this and this?
2003 Sonic Blue GT Vert
SonicBlue is offline   Reply With Quote
Old 03-09-2014, 10:34 PM   #11
Region: Utah
Thank You for the info.
Old 03-11-2014, 12:34 PM   #12
Thanks and no I haven't. $500 is overpriced. That 75 seems good.
Old 03-16-2014, 07:42 PM   #13
Peterzinyou's Avatar
Crutchfield b the way to go Theyswe you all harnesses and diagrams you need, as well as Tech Support. What year IS Your car ? I replaced the H/u lnmy '04 and I had to buy BASS BLOCKERS for the tweeters in the door Other than that T-+15 so much nicer with a modern H/u Good Luck.
Sent from my SM-N900T using Mustang Evolution mobile app
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Old 03-16-2014, 07:45 PM   #14
Originally Posted by Peterzinyou View Post
Crutchfield b the way to go Theyswe you all harnesses and diagrams you need, as well as Tech Support. What year IS Your car ? I replaced the H/u lnmy '04 and I had to buy BASS BLOCKERS for the tweeters in the door Other than that it is so much nicer with a modern H/u Good Luck.
stock sound system vs. shaker audio system (2014 Mustang) Charlesph55 Mustang Audio & Video 6 02-15-2017 06:11 AM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Mach 1000 system. Head unit and subs an amps 1995boss Mustang Parts for Sale and Wanted 8 03-26-2012 07:23 PM
mustang mach system alex_ander01 Pre-2005 V6 Mustang 8 12-15-2011 07:22 PM
replacing mach 460 sound system in 96 gt?? vinnygt Mustang Audio & Video 25 06-28-2011 10:13 PM
01:00 AM
