Amp Remote Wire - Mustang Evolution
Old 05-15-2014, 09:04 PM   #1
Socal Stangman's Avatar
Amp Remote Wire
I'm adding a sub amp and I need a remote wire, where's a good place to tap into one?
Old 05-15-2014, 09:36 PM   #2
The blue wire on your head unit
Old 05-16-2014, 07:27 AM   #3
Sorry I wasn't clear. I'm looking for some place to tap the blue wire in the trunk.
Old 05-16-2014, 07:28 AM   #4
Send a message via AIM to Borii
Just run it.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 05-16-2014, 10:58 AM   #5
NoSlo5oH's Avatar
If you run a PAC AOEM FRD24 which plugs inline with the factory radio and wiring harness, you can use the harness section of the PAC piece. Just cut off the Molex connector and solder RCA plugs onto the speaker wires to feed your amp. The harness has a remote lead already built into it, so that you don't have to tap into any factory wiring.
NoSlo5oH is offline   Reply With Quote
Old 05-16-2014, 11:05 AM   #6
Adogg's Avatar
For best results just run it to your radio, did it in my car it's not hard and work fine. Did you run you power cable to your battery?
Don't hate....... appreciate
Old 05-16-2014, 11:19 AM   #7
I know its not hard I just dont want to run it. I just did a HU replacement with the idatalink kit and I dont want to have to take it all apart again just for this wire. I read some where that you can tap into the antenna, can anyone confirm this?
Old 05-16-2014, 03:52 PM   #8
samuelsmith's Avatar
Have you checked the reverse lights power wire? They should work.
Old 05-16-2014, 05:21 PM   #9
He's only going to bump when he's in reverse
Old 05-17-2014, 07:20 PM   #10
BigCiv's Avatar
Can confirm that you can tap into the antenna wire, that's what I did. I followed a write up from another forum and it worked perfectly.
How To: Add a sub and amp to a 2013 - MustangForums.com
BigCiv is offline   Reply With Quote
Old 05-19-2014, 04:06 PM   #11
Perfect. Thanks a lot!!
Need to connect red wire to gray wire. clflorida Pre-2005 V6 Mustang 4 08-06-2013 06:46 PM
2011 GT Remote Wire Issues Untamed5.0 Mustang Audio & Video 4 04-18-2012 09:08 AM
same gauge wire for mono amp as multi-channel? tedness Mustang Audio & Video 5 05-05-2005 05:21 PM
Help! Remote wire color BuddyLee Mustang Audio & Video 18 03-12-2005 07:48 AM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
10:02 AM
