Shaker 500 sub addition - Mustang Evolution
Old 05-18-2014, 10:47 PM   #1
Whitelightning's Avatar
What's up guys, I have a 2011 premium with the shaker 500 system. It's pretty good over many stock systems but I love the thump.
I do have a mojo block amp and a alpine type r from my last mustang. I plan to keep the stock head unit as it's wrapped in carbon fiber and I have the sync system as well.
How do I go about wiring the sub and amp up on the stock head unit? Another problem is that there are 2 amps under the driver side. Or I think they are. Where do I start? Click image for larger version
Name:	ImageUploadedByMustang Evolution1400474846.390596.jpg
Old 05-19-2014, 09:08 AM   #2
Blogger
99ford's Avatar
those 2 Amps are bolted to the fender.
Sorry I'm not much help, Coty. I can at least bump it up for you.
Old 05-19-2014, 10:02 AM   #3
Here are the two amps under the driver side kick panel Click image for larger version
Name:	ImageUploadedByMustang Evolution1400515375.178451.jpg
Old 05-24-2014, 12:12 PM   #4
XxVenomxX's Avatar
I also have a 2011 premium but I just want to put subs in the back but I don't want to remove my factory speakers.
Any suggestions?
XxVenomxX is offline   Reply With Quote
Old 07-14-2014, 03:27 AM   #5
Zacrk's Avatar
To do that you will need to splice in an RCA box. There between 10-20 for them. The factory radio doesn't have RCA jacks. After that it's like any other radio installment. Run the power wire run a remote and ground it just like any other aftermarket setup
Zac
Zacrk is offline   Reply With Quote
Old 07-21-2014, 08:41 PM   #6
Cbird's Avatar
Region: Iowa
I Yeah I believe those boxes are called speaker level converters.
You splice into your back speakers, run wires from your back speakers to the box's input, then you run RCA cables from the box to your amp. Good to go.
I picked up a scosche one from Walmart and it works just fine. Solid voltage, no feedback noise at all, small size and hides away nicely in our trunks.
Because you spliced into the speakers it is going to send your sub amp a full range signal. Make sure. To properly tune the LPF before turning on the system, happened to me lol
Sent from my SPH-L710 using Mustang Evolution mobile app
Cbird is offline   Reply With Quote
Old 07-22-2014, 08:26 AM   #7
Zacrk's Avatar
They called it a step down. I payched one in recently in mine it works great i finally have my cvr 12" back in my car lol
Zac
Old 07-22-2014, 08:28 AM   #8
Zacrk's Avatar
Patched * and the only reason i get feedback is cause i haven't ground out the box yet. And you can patch it in at the stereo to if you want.
Zac
Old 07-22-2014, 08:33 AM   #9
Cbird's Avatar
Region: Iowa
Is a nickname for it a step down? The packaging of my unit says speaker level converter. Who knows? Lol
Old 07-22-2014, 08:41 AM   #10
Zacrk's Avatar
Well idk. That was probably the company name on yours but i thing the name of what it does is called a step down.
Zac
Old 07-22-2014, 09:28 AM   #11
Zacrk's Avatar
The company mine cane from was called pac
Zac
Old 11-06-2014, 06:18 PM   #12
Compstall's Avatar
It's called a line level converter
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Shaker 500 to shaker 1000 Magua10 2005-2010 Mustang GT 7 05-12-2014 06:20 AM
Shaker 500 door sub not working Zgradt10 2005-2010 Mustang GT 6 12-12-2012 09:12 PM
Shaker 1000 sub question RVAStang05 Mustang Audio & Video 0 02-18-2012 08:43 AM
Instructions for adding a sub to the Shaker 500 Evilcartman Mustang Audio & Video 3 08-03-2011 11:36 PM
mach 1000 sub addition 03GT88 Mustang Audio & Video 3 06-11-2011 10:14 PM
07:38 PM
