Installed a new touch screen radio - Mustang Evolution
Old 05-21-2014, 02:07 PM   #1
mazen123's Avatar
Installed a pioneer avh x1600 dvd touch screen stereo! I recommend all to do this! Completely changed your interior look and makes them feel way less old! Im later installing a back up camera also. Very easy to do for both. Click image for larger version
Name:	ImageUploadedByMustang Evolution1400703129.669996.jpg
mazen123 is offline   Reply With Quote
Old 05-21-2014, 02:40 PM   #2
610swolf's Avatar
looks good! I'm trying to save some money right now but I may invest in something like that later
610swolf is offline   Reply With Quote
Old 05-21-2014, 05:15 PM   #3
04__gt's Avatar
[ATTACH]157481 can you tell I got mine from a guy with a termi
Sent from my SM-N900V using Mustang Evolution mobile app
04__gt is offline   Reply With Quote
Old 05-21-2014, 11:15 PM   #4
behemoth's Avatar
Region: Oregon
Touch screen
behemoth is offline   Reply With Quote
Old 05-21-2014, 11:19 PM   #5
behemoth's Avatar
Region: Oregon
Touch scren
Old 05-25-2014, 06:47 PM   #6
GodKreatedDude's Avatar
Originally Posted by mazen123 View Post
Installed a pioneer avh x1600 dvd touch screen stereo! I recommend all to do this! Completely changed your interior look and makes them feel way less old! Im later installing a back up camera also. Very easy to do for both. Attachment 157471
my local shop said they didn't know how to do this! i think that's sad..
GodKreatedDude is offline   Reply With Quote
Old 05-25-2014, 07:22 PM   #7
mazen123's Avatar
Lol!! Thats crazy. It really is simple. 5 things needed.
1. Stereo
2.double din dash kit
3.speaker wire harness
4.amp wire harness
5. Bypass cable (to use the full features of the stereo while not parked)
Its just simple color wiring and a few obvious screws here and there
Old 05-25-2014, 09:27 PM   #8
where can i getall that and how much
Old 05-25-2014, 09:38 PM   #9
mazen123's Avatar
http://www.amazon.com/gp/aw/d/B006CT...1075324&sr=8-2
http://www.amazon.com/gp/aw/d/B00EZP...1075371&sr=8-1
http://www.amazon.com/gp/aw/d/B000K5...1075415&sr=8-3
Pick any DOUBLE DIN radio to go with those, I suggest pioneer (best in the world)
Thats all you'll need
Old 05-30-2014, 01:33 AM   #10
Blakhwk's Avatar
Sweet!
Visca Barça
Blakhwk is offline   Reply With Quote
Old 06-05-2014, 07:27 PM   #11
MRYANWEBB's Avatar
I have the same stereo that I wish to install in my car. My father recently passed away and he was the one who always did the work to my car, and I was hoping to do this install on my own. I was wondering how hard this install was and if it would be possible for me to do it..I am capable of doing minor things when it comes to cars simply from being around dad so much. I was wondering if you could give me a quick install run through since I can't find instructions anywhere. I was also wondering how hard this would be since my Mustang has already had a Pioneer stereo in it before(currently).
MRYANWEBB is offline   Reply With Quote
Old 06-06-2014, 12:15 AM   #12
behemoth's Avatar
Region: Oregon
It depends on what yr mustang you have also the model like mine I had to custom fiberglass my bezel because a double din bezel doesnt fit into the slots I have
Old 06-08-2014, 08:22 PM   #13
MRYANWEBB's Avatar
My Mustang is a 2003
Old 07-02-2014, 11:47 PM   #14
sebasflorez's Avatar
1. Stereo
4.amp wire harness
Bypass cable is not necessary, just ground the wire that's supposed to connect to the hand brake. Just thought i'd throw that out there since i also installed a double din touchscreen radio to my car.
Sent from my iPhone using Mustang Evo
sebasflorez is offline   Reply With Quote
Old 07-04-2014, 04:47 PM   #15
mazen123's Avatar
Depends on the type of touch screen. The newest pioneers are more advanced and that doesnt work anymore
Old 07-21-2014, 12:26 PM   #16
Cbird's Avatar
Region: Iowa
I believe I have the avh2600BT model (needed blue tooth and a 8 band eq) and I love it aswell.
The auto eq feature is also very good.
Grab a Bluetooth obd2 transmitter and you can see your gauges, in real time, on your radio. HP/torque and really the only cool gauges to look at though.
Sent from my SPH-L710 using Mustang Evolution mobile app
Cbird is offline   Reply With Quote
Old 07-21-2014, 12:27 PM   #17
Cbird's Avatar
Region: Iowa
You have to use a switch now. If it's grounded when the radio turns on it won't work.
Yes that means you have to pull the parking brake twice to get it to work too.
Old 07-21-2014, 04:46 PM   #18
behemoth's Avatar
Region: Oregon
What y'all know about big 3
Old 07-21-2014, 07:16 PM   #19
Cbird's Avatar
Region: Iowa
It's a little tricky on these motors because the alternator post sits under the throttle body, but the rest is pretty straight forward. Engine ground is easier than most.
Old 07-21-2014, 08:15 PM   #20
behemoth's Avatar
Region: Oregon
Well my alt is right side where do ground to motor? Also should there be a fuse from alt to battery if so what size
Old 07-21-2014, 08:16 PM   #21
behemoth's Avatar
Region: Oregon
2000 v6 mustang 1800 Kenwood amp 2 1000 watt alpine type r
Old 07-21-2014, 08:26 PM   #22
Cbird's Avatar
Region: Iowa
Oh I guess I just figured you had a 05-09 Mustang like me :O my bad haha
The alternator is very easy to do on the 99-04 mustangs. It's a straight shot to the battery. The ground to chassis, also easy. Just ground the the frame right next to the battery box (make sure to sand the paint down to bare metal though)
To find the motor ground you can actually just follow the wire from the negative battery post down to the bottom of the motor. That's where your motor is grounded too. It's a little tricky to reach, so a good extention will be in order to reach that bolt. 6" should be plenty.
The positive wire from alt to battery doesn't need to be fused as you want all the electricity going from alt to battery as possible. The more the better
Happy hunting
Old 07-24-2014, 08:58 PM   #23
Adriangozal's Avatar
Looks very nice, definitely going to consider installing a double din stereo.
Adriangozal is offline   Reply With Quote
8" touch screen-yes, EIGHT m_tyler_r Mustang Audio & Video 54 01-10-2013 01:50 PM
Touch screen with Ford's SYNC EdgeLivin Mustang Audio & Video 3 07-18-2012 05:45 PM
Change Shaker 1000 to Touch Screen stanglexGT05 2005-2010 Mustang GT 11 07-05-2012 03:29 PM
A good touch screen nav? JR_GT500 Mustang Audio & Video 7 02-26-2012 10:59 PM
Clarion Touch Screen DVD/CD/MP3 Mediastation Matt@StangMods Mustang Parts for Sale and Wanted 2 08-16-2005 07:28 PM
08:45 AM
