Raxiom gps looses signal - Mustang Evolution
Old 05-27-2014, 04:11 PM   #1
Any others having problem with Raxiom signal loosing satellites?
I updated SIM card etc!
snareyt is offline   Reply With Quote
Old 05-28-2014, 11:47 AM   #2
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
This is the first I'm hearing of this. We have a ton of customers out there running this unit without any issues. I have the nav installed in my 2011 GT and haven't had a single issue. The only time I've ever lost Signal is if I'm in a fully enclosed tunnel.
When are you loosing signal?
-Dan
Old 05-28-2014, 04:00 PM   #3
Really first time hearing this!
I emailed AM today and am waiting for second reply after
Answering usual questions, update card, reset unit etc.
I am sure we will get this resolved!
Thanks for your concern and attention.
Old 05-29-2014, 07:59 AM   #4
AmericanMuscle.com
Sponsor
Yes. We'll definitely get you taken care of. We'll be in contact with you and manufacturer and this should be quick. Let me know if you need any assistance from me directly!
-Dan
Old 05-30-2014, 04:26 PM   #5
bellski's Avatar
I just had my Raxiom installed today and am actually having the same problem. I will have GPS signal and then it will just drop off, and the unit will search and search, not to be rediscovered. It actually happened a little while ago while I was sitting at a stop sign- not even moving. Sure would like to know what can be done about this. FYI this is happening on a beautiful cloudless day, in the wide open with zero overhead obstructions.
Thanks,
Steve
2011 GT M6 Premium- Mechanical upgrades include: Boss 302 Intake, JLT CAI, JPC LT Headers, Off Road X Pipe, and mufflers, 410 Gears, Granatelli Hot Street Coil Packs, 93 Octane Ghost Cam Tune by Jon Lund,Eibach ProKit Springs,shocks, struts and sway bars, BMR LCA's, Strut Tower Brace, and adjustable Panhard Bar, Maximum Motorsports Camber/Caster Plates, Barton Shortshifter and bracket, Wilwood Superlight Brakes w/6 and 4 piston calipers, Steeda Spyders- 9-1/2X20 with 275/35 and 11X20 with 315/35 Nitto Invos.
bellski is offline   Reply With Quote
Old 05-31-2014, 07:25 AM   #6
Steve you may try some of the things I did. There is a SIM card behind the fake button on rt front of unit.
It can be opened by prying on left side and is hinged on rt. There is also a reset Hole there.
The card can be updated on a computer by registering on line at www.naviextras.com
Rosen entertainment systems inc. who is the manufacture of these units. DB Mustang.
My antenna is located on ft window behind mirror. I also checked all wiring.
All of this made no difference on mine! I am not sure if Bluetooth phone is causing a problem or backup camera may influence the gps signal? Maybe the SIM card is faulty? Mine will quit after about 30 min and will not work again until I wait with car off for 20 min! I have left car in garage with key on engine not running and After 30 min or so the signal dropped off and unit tries to acquire satellites! This has happened on every road trip and sometimes the signal did come back for a while only to quit again.
I think it is a unit warmup problem and will need replaced. Rosen and AM are both hoping for a solution.
I really like the unit but I don't tend to get lost on 30 min drives from my house 😊
Keep me posted on your experience.
Terry
Old 05-31-2014, 08:58 AM   #7
bellski's Avatar
Terry- thanks for your reply- I will try as you suggested and hope for the best.
Frustrating and disappointing to say the least...
I am taking my car on the Hot Rod Power Tour later this month, and was hoping the unit would be working 100% then and I would be able to sing it's praises when asked about it...
Steve
Old 06-04-2014, 05:15 AM   #8
Steve
AM sent me a new unit today!
They do have a 2 year warranty on unit I believe.
If the update doesn't do it then I know they will do
"Right by you"
Keep me posted or feel free for any info you may need.
Terry
Old 06-04-2014, 06:29 AM   #9
bellski's Avatar
Terry-
Thanks for the update- please let me know if this one works better. I emailed AM on Sunday about this- to date there has been no response.
Steve
Old 06-04-2014, 05:14 PM   #10
I installed today and in garage works great! Since my GT 500 doesn't have windshield wipers and it is raining, I did not test drive,😄
Left on for 1 hr. In garage and seems fine! I really love the units looks and functionality!
I will keep you posted!
Old 06-07-2014, 01:47 PM   #11
Raxiom gps unit loosing signal
Also loosing signal on my new raxiom unit installed 2 weeks ago. I have updated the SD card from naviextras.com as well under the Rosen entertainment, then choosing mustang DB as my device. completed all updates, still having connection issues. The unit says I'm in Texas, while i live in southern new jersey. Navigation worked for 3 days, then just never saw the light of signal again! What seems to be the solution to all this? i have not contacted AM yet. Other then that, i must say raxiom has done a hell of a job with this unit by creating lots of functions.
Kgoose3789 is offline   Reply With Quote
Old 06-08-2014, 08:17 PM   #12
Sounds a little different from what I experienced.
Could double ck all connections. When I did install I cut loose
Some wiring original tie downs to give more free play so new connections were not under tension.
My suspicion is a faulty unit but it is best to check everything first.
Hope I am wrong!
Keep me posted.
Terry
Old 06-09-2014, 06:09 AM   #13
b2673ad's Avatar
Hello
I had the same frustrating issue with my Raxion GPS unit. 3 months of signal loss.
I finally solved the problem with a new GPS unit.
Here is a copy of the Email I just sent to my AM POC.
Friday night I replaced the GPS unit andreconnected it to the existing antenna ( antenna #2) and I had the sameissue. No signal. As a last resort I installed the antenna thatcame with the replacement GPS and I move the antenna cable routing up throughthe passenger door molding and up over to the review mirror area. Bingo everything working like a champ. I did take the Mustang for 75 mile road trip on Saturday and used the route option on the GPS and itworked just fine.
So at this point I am not sure what theissue was. GPS unit?, antenna? Or the routing of the antenna cable through thedash in front of the driver/steering wheel.
So if you have your antenna cable wire routed through the dash board in front of the steering wheel it may be possible that the antenna is picking up electrical interference and blocking the signal.
You can read my thread on this page to see everything I went through to get this problem solved. I was in contact with the Rosan Tech Support and I did complete the map update and the used the reset button.
There must be an issue.
K
Kevin C.
2015 Roush RS1 Premium w PP
Roush Performance upgrade-- Tinted Windows
JLT Catch Can--Ford Racing Strut Brace
Flowmaster scavenger "Y" pipe resonator delete
b2673ad is offline   Reply With Quote
Old 06-09-2014, 08:13 PM   #14
I also ran the cable in front of drivers side. So far the new gps unit seems to be working fine
But have not had a chance to test on road for over 1 hour. This new unit will keep signal in garage
For over 45 min where my old one quit around 30 min depending on air Temp and on every road trip it quit!
I am surprised your new unit lost signal with old gps antenna!
I was convinced it was a warm up problem with gps unit until now!
We all want to know why because it is a great unit if the bugs get worked out.
I really like this unit and hope Radon is successful with it.
Thanks for responding.
Old 06-09-2014, 08:17 PM   #15
yes, i even just tried to place the antenna on the roof of my car hoping it would pick up satellites but still had no response to locating. tried to let this search for 45 mins with no luck. i will be in touch with americanmuscle.com to try and mitigate what is the issue or if i can exchange for a new unit if this is a faulty device. Click image for larger version
Name:	ImageUploadedByMustang Evolution1402366588.653298.jpg
Old 06-09-2014, 08:23 PM   #16
I know that picture well! Haven't seen it since new unit! What's that tell you!
Mine would reacquire signal if I left car off for 20 min.
Keep us posted!
Thanks for reply
Old 06-10-2014, 04:48 AM   #17
when you exchanged your unit, did they send you a new one first then ship old unit back? or do they want u to send yours back first then once they track some movement they then send you a new one? i hope the first option only because i dont want to be without a radio
Old 06-10-2014, 04:54 AM   #18
If you are willing to pay for a second unit first then when you send unit back
They will credit account. Otherwise you have to send unit first which means retuning
All cables etc. I bought second unit and just installed gps unit only! I wasn't willing to
Do a complete install. If they just sent new unit some people might keep both!
Old 06-10-2014, 04:56 AM   #19
If you get second unit they also pay shipping
Old 06-10-2014, 06:17 AM   #20
b2673ad's Avatar
Update
They sent me a second unit and today I am shipping the first unit back to AM. I did not install the first unit so I said no way am I taking it out and hiding my car while they send me a new unit.
I did go test drive my car again last night and the system worked just fine so I hope I am over this issue.
K
Kevin C.
Old 06-10-2014, 02:48 PM   #21
I also hope so! Enjoy this one.
Old 06-11-2014, 04:00 PM   #22
b2673ad's Avatar
Kevin C.
Old 06-11-2014, 04:24 PM   #23
Won't get lost in North Charleston, SC!
Old 06-12-2014, 10:17 AM   #24
b2673ad's Avatar
Hello
It is kind of strange that the AM online reviews are all positive up to October 2013.
I know I sent a poor review in on the AM site and it never showed up.
After I give my unit some time to perform properly I will submit an updated review.
K
Kevin C.
Old 06-12-2014, 10:31 AM   #25
Like most things in life the press is controlled!
That's why I said ;really; back to AM about first time hearing this.
Everybody seems to have there own agenda!
At least we we're take care of by AM
I can't fault them for that.
Old 06-12-2014, 11:05 AM   #26
b2673ad's Avatar
Not trying to drag AM through the mud but just stating facts.
BTW I did just order a tuner from AM for my car
Kevin C.
Old 06-12-2014, 04:15 PM   #27
Yea I was looking at those myself!
Let me know the results if you would.
My. 2011 shelby has enough hp for me
But everything before but is !!!!!!! LOL
I didn't think you were knocking AM and I
Couldn't agree more with what you said.
Thanks
Enjoy
Old 06-14-2014, 06:50 PM   #28
Today we gave the replacement gps unit a good test of 100 miles and it
Worked great! The only thing I changed was the gps unit! Still using
Old gps antenna and wiring! I am convinced the problem is solved!
I will update in future if I have any problems but don't expect to!
Thanks everyone for all the input!
Feel free to ask me any questions about installing etc.
Really love the unit.
Having fun in Beaver Falls , Pa 😊
Old 06-16-2014, 05:47 AM   #29
b2673ad's Avatar
Good news
Mine seems to be working fine also.
My issue is that I can not see the screen with my sunglasses on.
K
Kevin C.
Old 06-16-2014, 04:34 PM   #30
Dan Aykroyd and John Belushi had the same problem 😄
I manually hit the bright button for screen since I drive with lights on in daytime.
1 push off 2 bright 3 dim
As soon as lights are turned on it defaults to dim.
We did another trip yesterday and worked great.
Problem solved!
Old 06-17-2014, 05:25 AM   #31
b2673ad's Avatar
Hey
Bright button in the GPS settings?
K
Kevin C.
Old 06-17-2014, 11:15 AM   #32
forceflow2's Avatar
He's talking about the Disp hard button on the left. It will cycle between bright, dim, and off for the screen.
2013 V6 Premium GHIG purchased 01/16/13
forceflow2 is offline   Reply With Quote
Old 06-17-2014, 12:17 PM   #33
The button right above the nav button
Old 06-20-2014, 05:04 PM   #34
bellski's Avatar
Hey all-
Wanted to update you on what has happened since I last posted on this thread. I emailed customer service on AM's website and got very unsatisfactory response to my problem. It seems that they only check there email every 3rd day or so, and once they finally agreed that the Raxiom unit was defective, they told me that I would have to pull it out and send it to them, and that they would, upon receipt of mine, send me a new one. They were completely inflexible about this and stated that it was their policy to do it this way. I got pretty frustrated with this as it meant I would be sitting with a dismantled dash for 10 days or so until I would be able to get the replacement installed. I agonized over this for a while, then I finally picked up the phone and called them (duh). The experience I had dealing with them over the phone was 100 times, no, 1000 times better than email. The guy I talked to on the phone was very understanding and told me that upon approval from his supervisor, he would send me a new unit and emailed me a UPS return label to send the old one back. The new Raxiom arrived today, I pulled the old one out, installed the new one and it works perfectly (so far at least). The old unit will be on it's way to AM tomorrow. As I told the AM customer service rep on the phone, he saved a very good customer for them. Note to self, next time, just pick up the phone.
Old 06-23-2014, 07:55 AM   #35
Hope your results will be as favorable as
Ours were!
Raxiom OE-Style GPS Navigation installation problems! JonathanMustang 2011-2014 Mustang GT 17 04-08-2018 12:49 PM
Raxiom OE-Style GPS Navigation w/ Bluetooth & Back-up Camera (10-14) DWC_SmOziLLa AmericanMuscle 112 04-17-2016 07:42 PM
Raxiom GPS Bluetooth Navigation Installation Help JonathanMustang 2011-2014 Mustang GT 3 11-12-2013 09:54 PM
No gps signal on nav in 13 gt? Mustang32Bill Mustang Audio & Video 1 07-03-2013 02:19 PM
07:28 AM
