Signal Processor for a Factory Stereo Upgrade - Mustang Evolution
Old 06-06-2014, 10:26 PM   #1
blueprint87's Avatar
Looking to upgrade factory stereo in 2012 V6 but have decided I want to keep the factory unit. I'm looking at signal processors (JL Audio's Clean Sweep or Kicker's Front Row). I'm looking for advice on this upgrade, thoughts on the processors, and/or alternative suggestions aside from replacing the head unit.
blueprint87 is offline   Reply With Quote
Old 06-07-2014, 05:36 AM   #2
NoSlo5oH's Avatar
I was looking at a JL Audio Clean Sweep when I upgraded the factory stereo in my '13 GT. However, I decided to go with an AudioControl DQDX processor instead. The DQDX is better IMO in that it has lots more features; including a 7 band equalizer (a total of 21 knobs), for the front, rear and sub. It also has a crossover and a delay feature which allows the end user to delay/move the sound around in the car for the best possible sound. In addition to that, it has pink noise built into it to aid in the tuning process. Lastly, if you remove the cover on the DQDX you can access advanced features like different jumpers to help with grounding issues or even jumper the front speaker signal over to the sub output and eliminate the need for a LOC. I'm running a JL400/4 for my front and rear deck speakers and a JL 300/1 for my factory Shaker Pro sub. I recommend getting a PAC AOEM FRD24, cutting off the Molex connector for the speaker wires and soldering on RCA plugs to keep you from having to hack up your factory harness. You will not need to use the rest of the PAC unit. I hope this helps.
NoSlo5oH is offline   Reply With Quote
Old 06-07-2014, 05:42 AM   #3
NoSlo5oH's Avatar
Here is a pic of the modified PAC harness with the RCA connectors soldered on. It simply plugs into the factory radio harness and then into the factory radio.
Old 06-07-2014, 08:38 AM   #4
That is helpful. Thank you!
Old 06-18-2014, 05:43 AM   #5
Ratraget's Avatar
Where do I get this harness
Ratraget is offline   Reply With Quote
Old 06-18-2014, 04:08 PM   #6
NoSlo5oH's Avatar
Best Buy and Crutchfield carry them.
Sound processor/equalizer + subwoofer bazinga11 Mustang Audio & Video 16 03-13-2014 11:21 PM
Bass processor (epicenter) Joser714 Mustang Audio & Video 0 01-23-2014 06:35 AM
Factory stereo system Amp mustang2000 Pre-2005 V6 Mustang 3 11-02-2011 05:11 PM
Need Factory 02 Mach stereo at7311 Mustang Audio & Video 13 08-20-2008 07:08 AM
Need help getting processor specs.... SpectorV The Bar 0 08-21-2004 01:33 PM
07:07 PM
