Changing to doubled in on 97 GT. - Mustang Evolution
Old 07-20-2014, 05:12 AM   #1
Polar Bear's Avatar
Region: Asia
Is it possible to change to double din system on a 97 GT? I know I would need a different console. Do they make them?
Steve
Polar Bear is offline   Reply With Quote
Old 07-21-2014, 04:30 AM   #2
Polar Bear's Avatar
Region: Asia
Will a 01-04 double din bezel fit?
Steve
Old 07-22-2014, 08:31 AM   #3
Prokiller's Avatar
yes it will fit but you will also need the shifter bezel portion as well to match up. also to note, the color doesn't quite match up as they are going to be charcoal, not black. most guys will also make a bracket because it doesn't quite mount the same and can be a little flimsy with the extra weight of a double din unit.
DSS 331 Super Pro Bullet, Vortech V-2 SQ w/ Power Pipe, AFR Comp 185 heads, Performer RPM intake, AFM B-21 cam, AFM PMS, T3550 tranny, Black Machined TSW Nurburgring wheels 19/20s and stuff....
Prokiller is offline   Reply With Quote
Old 08-05-2014, 11:15 PM   #4
SGKustomz's Avatar
Region: Oregon
It should not 100% tho... this was one of the first things did in my 99 revive. The dash is pretty similar but may require a little work to fit on a 97. As for the 99 swap I bought the Mach version replacement surround from my local pick n pull for 45 bucks. It's a pretty straight foreword swap just remove the shifter trim then the radio and cd changer using a couple paperclips or the ford removal tool. once they are out the bezel is pressure clipped into place just be careful not to force on a corner try to pop from middle the work your way out.
ID:	162965   Click image for larger version
ID:	162967   Click image for larger version
SGKustomz is offline   Reply With Quote
Old 08-07-2014, 09:27 AM   #5
SGKustomz's Avatar
Region: Oregon
There are a couple screws holding the radio frame to the dash two on the bottom of the bezel you can see right above the shifter trim. The other two are above the cd changer pointing down... You can see the holes on the pic
Changing headers on a 2000 gt. Black00GT 1996-2004 Mustang GT 9 03-17-2004 01:02 PM
Think changing your oil every 3k miles is good? Think again Monkey Pre-2005 V6 Mustang 14 02-24-2004 05:39 PM
Changing Color Pattern? Shahrum Mustang Audio & Video 25 01-13-2004 09:11 PM
Explain how exhaust note is changed when changing the Cam. MusclesFromBrussels Pre-2005 V6 Mustang 32 11-06-2003 07:31 AM
changing my favorite show, ever tire The Bar 35 08-04-2003 11:37 PM
05:23 PM
