Wiring harness - Mustang Evolution
Old 08-21-2014, 02:44 AM   #1
iantrusive's Avatar
Wiring harness
I have a 2013 base mustang, no shaker. I installed my stereo and couldn't get it to work, stereo works fine when I connect the red (ignition/acc) wire to the yellow (battery) wire. So the problem is my ignition switch wire isn't working. Does anyone have a pin layout for the factory female harness, or know which pin is the ignition wire? I think it may be lined up wrong. If not, then I'll check every fuse and then take it to a shop when all else fails. Thanks.
iantrusive is offline   Reply With Quote
Old 08-24-2014, 08:32 PM   #2
does the radio not turn off when the key is turned off? If I had to guess, swap the red and yellow wires. You did buy a radio to factory harness right?
Colorado Corey is offline   Reply With Quote
1995 Wiring Harness Farah51 1979-1995 Mustang GT 1 03-16-2009 03:56 PM
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 09:59 PM
Eclipse CD3100 + wiring harness & double din adapter jimmy_beaner Mustang Parts for Sale and Wanted 2 04-07-2008 06:56 PM
what wiring harness Zim Mustang Audio & Video 9 01-10-2006 08:37 AM
Do you think its worth it - modify wiring harness myself or pay a pro????? fast64 The Bar 8 11-09-2004 09:32 PM
01:56 PM
