Mach 460, need help to start troubleshooting - Mustang Evolution
Old 08-25-2014, 05:33 PM   #1
Splogan's Avatar
I have a 95 GT vert. I recently installed a new Kenwood in dash receiver. I put in the 5 volt converter so no popping like the unit that came out. I have noticed, the top rear speakers do not work. The subs below do and the fronts all work. I used wiring harness adapters so those should be good. If I move the audio to the front everything still works, including the factory subs by the rear seats. If I shift audio to the rear no sound at all. Could this be a blown amp in the Mach system or crossover in the system. I really don't know much about how the system is laid out to start troubleshooting.
1970 Mustang Fastback (Primer Gray)
1995 Mustang GT Convertible (Deep Forest Green)
2005 F-150 SCAB (Arizona Beige Metallic)
2016 Mustang GT, Fastback Perf Pack (Ingot Silver)
Splogan is offline   Reply With Quote
Old 08-26-2014, 01:18 PM   #2
I'm not sure what the converter does but, if you have an amplified stock system (obviously you do) most of the time you cannot run an aftermarket deck because you are running line power to the amp. I'm assuming the converter you have is between the deck and the stock amp? If so I would check, check, and recheck all my connections.
Sent from my EVO using Mustang Evolution mobile app
Colorado Corey is offline   Reply With Quote
Old 08-26-2014, 09:30 PM   #3
Splogan's Avatar
For the speakers there really was no connections to be made. Wiring harness plugged into stereo and then in to factory plug. the only connections were the power and grounds and such. The Mach is a weird system, hence looking for some input from those that know it well.
Old 08-27-2014, 06:47 AM   #4
OK well good luck
Old 08-27-2014, 08:32 AM   #5
Splogan's Avatar
I will tinker with it. If it get too crazy im sure Crutchfield will gladly sell me he the stuff to swap over to a conventional set up
Old 08-27-2014, 06:41 PM   #6
Splogan's Avatar
Score one for Crutchfield. I pulled the stereo and started chasing continuity. Turns out the solder joints in the adapter from the RCA amp pre-outs to the factory harness were bad. Called crutchfield and they are sending me a new adapter for free. Im glad it was just a ****ty adapter not not a blown crossover
abs+traction light on troubleshooting help speedshop23 Pre-2005 V6 Mustang 4 01-10-2014 03:44 PM
I need help with Mach 460! calebnaasko 1996-2004 Mustang GT 0 07-15-2013 11:18 PM
Mach 460 with Mach 1000 Subs XSlashDashX Mustang Audio & Video 2 05-31-2013 12:07 PM
May have hurt my motor, need troubleshooting ideas PureVenom 1996-2004 Mustang GT 22 01-27-2010 03:11 PM
Mach 460 headunit "CD error" problem, need help fast64 Mustang Audio & Video 7 05-02-2005 07:32 PM
02:07 PM
