New Edge Mustang Receiver Cut off - Mustang Evolution
Old 11-14-2014, 04:08 PM   #1
bkh1994's Avatar
I have a 2003 Mustang with Mach 460. About a year ago, I took out the stock HU and put a Kenwood receiver. I also have subs. Everything was working but then one day, it played for about a minute and cut off. I can't get it to cut on from the harness. I did get it to turn on by connecting it straight to the battery so the receiver is working.
I have a 12v to 5v converter to stop the "pop" when it turns on. I have the converter connected to the amp turn on wires, as it should be. I then have the amp ground grounded to the chassis. I then have the wires matching the harness adapter connected to the receiver harness. The adapter said to connect the grounds, not to ground them. I have tried both ways. I have redone all of the connections so that shouldn't be the problem. I used a tester and checked each connection and everywhere (including ground) is getting power. Previously I have had a short with the car harness and only working when I lift it, to counteract that problem, I had it ziptied higher up inside the dash. But that's not the problem, it won't turn on at all. My ground consists of: the amp ground (from the adapter harness) and the converter ground. I have also tried adding both grounds from the receiver and adapter. I don't know if there is something I'm missing or what could be wrong. Thanks
bkh1994 is offline   Reply With Quote
Old 11-19-2014, 07:32 AM   #2
bkh1994's Avatar
The yellow wire in my factory harness was dead. I ran a wire from the battery to the yellow and now the radio works. But now my subs don't. I've checked all fuses, all wires, the ground. The amp goes into protect mode as soon as you turn it on. Protect is on even with the speakers and rca cables unplugged. I'm thinking the amp just went bad, but I'm not sure
new edge
installed kenwood receiver Boss227 Mustang Audio & Video 7 09-06-2014 11:15 AM
Should i cut my resonators off? Mustang32Bill 2011-2014 Mustang GT 11 12-02-2012 11:41 AM
Jvc double-din receiver Venomouz831 Mustang Audio & Video 37 10-18-2012 03:39 PM
cut off my pipes strike1980 Pre-2005 V6 Mustang 7 01-01-2006 10:08 PM
Rev. Limiter Cut Off Donny B Pre-2005 V6 Mustang 10 12-25-2003 11:25 AM
12:16 PM
