Set Up Suggestions - Mustang Evolution
Old 11-16-2014, 04:43 PM   #1
JoeyM91's Avatar
Set Up Suggestions
So it's time to start working on the audio a bit and I'm pretty noobish when it comes to this, that's always been my brother's area.
I would like some suggestions of the setup I have planned.
I currently have 2 10" Kenwood KFC-W2513PS subs. (300w RMS, 1000w peak each, 4 ohm impedence).
I'm going to have him build me a box to house these. I asked him for a suggestion on an Amp and he swears by PPI, which I've never heard of.
For the door and rear speakers I want to use these Rockford Fosgates:
Rockford Fosgate Punch P1683 6"x8" 3-way car speakers at Crutchfield.com
My questions are what is a solid amp that will handle those loads and also, will I need a deep cycle battery to handle all of this extra load?
I have not changed my head unit just yet. I have a base car, no shaker system.
Old 11-16-2014, 05:03 PM   #2
Socal Stangman's Avatar
PPI used to be a much higher end company, now they are ok. I used some Rockford T series amps and they are some of the best I ever used. I had a bcd 1500 and 400/4. They did way more than rated power and never over heated. I highly recommend them.
Personally I would ditch the subs. Look around and try to find some Alpine Type R's. They are excellent budget woofers.
As far as batteries, I use my stock battery right now with very good results. If you want to buy one an Optima yellow top will work great.
Old 11-16-2014, 05:12 PM   #3
JoeyM91's Avatar
Thanks for the suggestion. I got these Kenwood for a steal is why I have them. I'm not looking for heavy output bass, just good and punchy.
I was looking at the Optima. My concern was this new load would drain the stock battery pretty quickly.
As far as the speakers I chose, any issues with those? The overall reviews seem good. One thought I had was if I'll run into any clearance issues in the door since these have built in tweeters.
Old 11-16-2014, 05:36 PM   #4
The speakers aren't to bad. Will you power them with the HU or an amp?
If you want to keep the Kenwoods I wouldn't feed them more than around 300 watts, they really can't handle much more than that.
Old 11-16-2014, 05:40 PM   #5
JoeyM91's Avatar
Going to do an amp since I have the stock head unit. I'll replace it later on, but not really wanting to drop $400+ on a new one just yet.
Old 12-08-2014, 09:55 PM   #6
I would not go with three way speakers all the way around it will be treble overkill.
Xtreme Boss is offline   Reply With Quote
Old 12-10-2014, 08:09 AM   #7
c_rizzle's Avatar
Do you plan on running the stereo with the car off ? If so then you should upgrade your battery as you'll end up with a dead battery quickly when running a large subwoofer amp. Or get one of these as your rescue solution: http://www.lowes.com/pd_573361-74342...&kpid=50179123
Though depleting the battery down regularly is not good for its life in the long run.
If you're generally only going to jam out (loud music) while the car is running then the stock battery is fine.
Though you should probably get a capacitor which will keep the sub amp from overwhelming the power system. If you've ever seen someone with a serious sound system and no capacitors, when they listen the music loud, you can sometimes see the lights in the car dim with the hard hits of bass..... well that's what a capacitor will fix... it will help store an little energy reserve between bass hits, so there will be no dip in voltage/power.
With what you're doing all you should need is like a 1.0 - 3.5 (max) Farad capacitor. You can go cheap (1.0 Farad with no digital read out) as they are VERY simple devices and should all work the same.
c_rizzle is offline   Reply With Quote
Will this set of pipes fit on my stang? Toomster Pre-2005 V6 Mustang 17 11-18-2003 02:15 PM
I have a dyno set up with Fordchip Danger Dude Pre-2005 V6 Mustang 0 11-07-2003 06:52 AM
Set a new best ET this weekend slvr2000stang Pre-2005 V6 Mustang 15 11-05-2003 08:43 PM
Convo with a Aim bot my friend set up on his screen name Rellik The Bar 10 10-29-2003 10:42 AM
I have found the TRUTH! and it has set me free Ken The Bar 13 10-24-2003 04:22 PM
11:50 PM
