2002 Gt aftermarket h/u install - Mustang Evolution
Old 12-09-2014, 05:52 PM   #1
2002gtmo's Avatar
OK so my main question is in regards to the mach 1000 system i have done aftermarket installs and all that but never with a factory sub and amp set up i heard there are 3 plugs for the h/u. Now here is the kicker I sold the amps and subs out of my car for 3 car payments! But do i need to worry about the 3rd plug in if i don't have any amps or subs in the back? And yes the plug ins are just hanging out in the trunk not connected to anything
2002gtmo is offline   Reply With Quote
Old 12-30-2014, 07:38 PM   #2
Slater2111's Avatar
There are 3 plugs in the dash as you describe. The largest one has all the speakers and tweeters in it. The smaller one has amp controls in it and the medium one that has only a couple wires aren't used when installing a new H/U. If the system works without the amps and subs now, you shouldn't have any problems with the new system. It is a pretty easy install. I soldered and shrink wrapped all my connections with the 12v to 5v amp turn on converter in about an hour. That's amps, main harness, grounds, and converter. So you shouldn't need to worry about the amps wiring harness in the dash. I hope this answered your question. You should only need the main harness.
Slater2111 is offline   Reply With Quote
Old 12-31-2014, 07:33 AM   #3
2002gtmo's Avatar
Well i got it figured out. Went to a local audio shop after trying two different harnesses and got the one with three plugs and hooked everything up and got everything working good as new. Turns out a all american rejects cd blew up in my stock head unit thats why the cd played didnt work!
Old 12-31-2014, 09:21 AM   #4
Slater2111's Avatar
Glad you got it figured out. I replaced my M1000 head unit on Sunday with a JVC touch screen. Did you fix your old one or replace it?
Old 12-31-2014, 09:53 AM   #5
2002gtmo's Avatar
Replaced it the thing was trashed damn mach head units had so much potential
Problem fitting aftermarket pop-out screen stereo into 2002 mustang rewind206 Mustang Audio & Video 0 01-08-2014 03:25 PM
I need to bypass my 460 mach stereo and install aftermarket cd player TattedUp Mustang Audio & Video 18 05-02-2012 09:32 AM
Where can i find the cheapest aftermarket parts for a 2002 mustang gt makis General Mustang Discussion 0 03-18-2010 07:00 PM
2002 mustang gt vs 2002 eclipse gt? diwali General Car Discussion 3 08-22-2009 05:58 AM
06:30 AM
