Shaker 1000 Door subwoofer replacement - Mustang Evolution
Old 01-26-2015, 04:42 PM   #1
PonyOnTheBeach's Avatar
I've been looking for subs to replace the ones in my door. Does anyone have any suggestions? I really don't want to spend more than $60 per subwoofer if I don't have to, but I would like to have decent sound. I know that you at what you pay for when It comes to sound equipment. Also, is there a reason for the plastic piece on the back of the stock subwoofer? Will it affect the sound if I have to cut it to fit a new speaker? Sorry about all of the questions, I don't have much knowledge when it comes to stereos.
It's all about the smiles per gallon
PonyOnTheBeach is offline   Reply With Quote
Old 01-27-2015, 01:34 PM   #2
WJBertrand's Avatar
These are plug and play, but about $30 over your limit perhaps. There aren't too many options that will fit.
Kicker Audio 8 Inch Woofers (Shaker) (2005-2014)
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 01-27-2015, 01:58 PM   #3
Ok, thanks I'll most likely pick those up. If I don't get those is it a bad idea to cut the plastic behind the speaker? Does it serve a purpose?
Old 01-27-2015, 02:43 PM   #4
ninerone's Avatar
These fit perfectly (once you remove the shell from the back of the speaker):
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
The plastic behind the speaker forms the air box; if you cut it you will be using the entire door panel as an air box and it'll probably sound terrible. I don't recommend it.
2014 GT / Black / 6-speed manual
Airaid CAI / Roush Exhaust / Bama Tune /
Custom Vinyl / Shelby Spoiler
ninerone is offline   Reply With Quote
Old 02-02-2015, 09:17 PM   #5
Socal Stangman's Avatar
The only ones that fit are the Shelby Kickers. Others will but will require modifications. Are you going to amp them? If not don't do it, it's not worth it. On the other side if you do amp them don't use any more than about 150 watts per sub. You'll also have to deaden the door because it will rattle like crazy...trust me on this I'm dealing with this right now.
Old 02-02-2015, 09:19 PM   #6
Well the passenger side sub sounds busted so I'm looking for a replacement.
Old 02-02-2015, 09:23 PM   #7
IF you are. It going to change anything but the sub I'll sell you my stock ones. PM and we can work it out. I have both of them.
Old 02-03-2015, 10:35 AM   #8
WJBertrand's Avatar
Amazon.com : Pioneer TS-SW2002D2 8-inch Shallow-Mount Subwoofer with 600 Watts Max Power : Electronics
These look extremely interesting because they appear to be dual voice coil, just like the OEMs. One of the problems with the Kickers is that you loose some volume because they are only single voice coil designs, leaving the leads for the other VC unused when they are fitted.
-Jeff-
Ventura, CA
Old 02-03-2015, 12:04 PM   #9
What other set of leads? They are SVC so they are only a positive and negative, thats it. I also agree with the volume thing. I cant stress enough, if you dont plan to amp these dont buy them!! You will be disappointed...
Old 02-03-2015, 01:43 PM   #10
WJBertrand's Avatar
The OEM Door subs on my 2013 are Dual Voice Coil and as such have two sets of leads and four terminals per speaker. The Pioneers also have four terminals and the specs indicate they are DVC with 2 ohms impedance each. This will accommodate both leads from the OEM amp. The Shelby Kicker upgrades are indeed SVC, so you cannot connect the other set of leads when using them.
Maybe other year model Mustange have SVC door subs?
-Jeff-
Ventura, CA
Old 02-03-2015, 02:06 PM   #11
ninerone's Avatar
These Pioneers are DVC. Since I've done everything aftermarket, I had no wiring at all, and ran just a single line and bridged it to both terminal pairs (which makes the impedance 1 ohm to the amp). I have a 600w amp driving both speakers (300w each) and it definitely rattles the doors at high volume. Fortunately, I'm only in it for bass response and I don't blast my radio like a 16 year old in a high school parking lot anymore, so at normal listening levels there's really no rattle and they pump out a good level of 80 Hz base.
Old 02-03-2015, 02:54 PM   #12
Oh I'm sorry I misunderstood. You mean there are extra wires? Right? If so I didn't use the stock wiring anyway so I took it out.
Old 03-24-2015, 03:59 PM   #13
k1DBLITZ's Avatar
You meant woofer, right? Not SUBwoofer?
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 07-17-2015, 03:22 PM   #14
Brewcityf6b's Avatar
Is the amp powering he door subs a single channel or two channel amp? I have a single channel kicker amp going unused that I'm thinking about adding to the Shelby kickers that I've ordered.
Sent from my XT1096 using Mustang Evolution mobile app
Brewcityf6b is offline   Reply With Quote
Shaker 500 to shaker 1000 Magua10 2005-2010 Mustang GT 7 05-12-2014 06:20 AM
For Sale: 2013 Shaker Pro Subwoofer DWC_SmOziLLa Mustang Parts for Sale and Wanted 12 07-07-2013 10:57 AM
02 GT Convertible Mach 1000 subwoofer Greeny1Stang Mustang Audio & Video 3 06-28-2012 09:24 PM
07:49 PM
