About to loose my mind with SYNC! - Mustang Evolution
Old 04-16-2015, 11:36 AM   #1
Dark_Pony's Avatar
I have tried everything I can think of to get my USB recognized so that I can (ironically) update the software to fix bugs like the USB but have failed at every corner. I tried formatting my memory card as FAT and FAT32, tried pulling the SYNC fuse (#3) for about 20 min, using the "install app" option instead of the autorun, even yelling USB!!! to it but still nothing. I either get "No USB" or "USB Empty". Anything I haven't tried??
2014 Sterling Grey FP6 w/ Tech package
Current Mods: Gibson exhaust; MMD hood scoop and side scoops; Tinted head lights, tail lights and all reflectors.
Dark_Pony is offline   Reply With Quote
Old 04-16-2015, 11:48 AM   #2
WJBertrand's Avatar
I was unable to update my Sync until I tried another, higher quality, USB drive. I went out and bought a brand new Sandisk drive and it worked the first time after many failed attempts with a different no-name USB stick.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 04-16-2015, 11:48 AM   #3
Dark_Pony's Avatar
I've also did the master reset but nothing. I am however using a micro SD in a USB carrier - but as long as its the right FAT32 format that shouldn't matter right?
Old 04-16-2015, 11:50 AM   #4
WJBertrand's Avatar
I would definitely try again with a good quality USB drive, not an SD card.
-Jeff-
Ventura, CA
Old 04-16-2015, 02:40 PM   #5
Dark_Pony's Avatar
Damn. I was hoping to avoid the cost of getting another one of these things. They are cheap sure, but I don't even have to buy peripherals to update my computer! Cmon Ford...
Old 04-16-2015, 06:45 PM   #6
oxford5pointoh's Avatar
Rip it out and don't look back. Sync is the biggest garbage ford ever put in a car
Old 04-17-2015, 05:22 PM   #7
GTgeorge's Avatar
What would you recommend. I was looking at the Raxiom radio system??
GTgeorge is offline   Reply With Quote
Old 04-20-2015, 02:29 PM   #8
I've found that using a 1gb USB works the best. You can take a larger one and create a smaller 1Gb partition. That should work as well.
KonaPony12 is offline   Reply With Quote
Old 04-20-2015, 02:47 PM   #9
The raxiom retains the sync. I recommend a complete aftermarket
Old 04-21-2015, 07:30 PM   #10
GTgeorge's Avatar
Please explain. How does it retain "the sync"?
Old 04-21-2015, 09:03 PM   #11
The raxiom basically ads a fancy interface. It doesn't change the radio or add functions other than nav and a back up camera.
Old 05-07-2015, 07:46 PM   #12
Bear376's Avatar
At least two manufacturers make replacement units that will retain steering wheel controls and offer CarPlay which is what will be available with Sync 3, but not available for older models.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 05-08-2015, 09:46 AM   #13
Is the backup camera hard to install?
Old 05-11-2015, 07:43 PM   #14
Member
Which ones are they? Id be interested in upgrading from sync. Pm me if you don't mind.
crbauhs is offline   Reply With Quote
Old 05-13-2015, 10:30 PM   #15
Bear376's Avatar
Check out crutchfield.com and do a search for carplay.
Old 05-28-2015, 06:43 PM   #16
Ok. Just did the sync update, on the 3rd USB drive (ironically the one I actually made myself) it finally found the files by navigating through a convoluted series of buttons on the radio. I followed the directions from this forum and another but wouldn't work. The download took 26 min using a 128 mbyte drive formatted fat32 (USB 1.1 fat32 drive I made).
I know this really isn't that helpful but it does seem to be USB dependent. I can tell you the microcontroller I used in my USB drive when I built it was a very popular one that is used by many manufacturers of USB drives.
Keep trying. It will eventually work.
Pminri (iPhone)
pminri is offline   Reply With Quote
Old 08-09-2015, 06:11 PM   #17
Try this for anyone who ever has this problem again. I know this thread is old but this may help another Click image for larger version
Name:	ImageUploadedByMustang Evolution1439165488.837270.jpg
Use the directions in the last paragraph.
Nathan
nthknd is offline   Reply With Quote
Today. Hell. Breaks. Loose. wiarumas The Bar 14 10-23-2005 11:45 AM
Loose clutch & Ford says it's normal WhiteThang Pre-2005 V6 Mustang 5 02-21-2005 10:27 PM
Idiot on the loose 04MonteSS The Bar 25 02-16-2005 04:47 PM
theres a wallaby loose in severn where i live...wtf!?! Bane- The Bar 4 10-13-2004 02:58 PM
Reported Drunk on the Loose Shahrum The Bar 11 03-18-2004 10:39 PM
08:16 PM
