White noise - Mustang Evolution
Old 04-17-2015, 09:23 AM   #1
20prima10's Avatar
White noise
Has anyone gotten white noise after installing new speakers and amping them? I installed my stangs system and it is fine. Did my buddy's the same way with same gear and have white noise. I've checked everything and can't rid it. Both cars are 2013
20prima10 is offline   Reply With Quote
Old 04-17-2015, 10:53 AM   #2
Check your grounds that's where you get EMI
oakleyxjl is offline   Reply With Quote
Old 04-17-2015, 12:34 PM   #3
20prima10's Avatar
Only ground I have not checked is the factory radio ground? I'm assuming that ground is good since its sounded fine from factory. I could be wrong though.
Old 04-17-2015, 12:58 PM   #4
Alot of factory speakers use the base of the speaker to ground to the chassis so Def make sure it had proper ground
Old 04-17-2015, 01:57 PM   #5
20prima10's Avatar
Ah ok. Guess I'll be pulling them both apart to check it out. Thank you. Hopefully that works.
White Saleens on white mach 1? MachMan1017 General Mustang Discussion 2 11-26-2012 07:41 PM
White on white or white on black? Ware12 Pre-2005 V6 Mustang 28 01-20-2012 11:49 AM
White noise :: 1968 Ford Mustang Shanes0406 Member Garages 0 06-15-2011 12:02 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
White car, white rims wiarumas Mustang Audio & Video 14 02-03-2004 11:23 AM
10:08 AM
