Running Raxiom GPS off factory satellite antenna - Mustang Evolution
Old 06-04-2015, 02:06 PM   #1
Commercial Member
au01st's Avatar
So, I believe I have sourced the parts needed to split the factory satellite radio antenna and provide a feed to both the radio and to the Raxiom GPS. This would save you from having to mount yet another thing and run yet another wire to get your GPS up and running. The Raxiom manual says that you can split the factory wire, but they provide no information on how to do it.
Well the source I found it's cheaper to buy 50 than it is to buy 5 due to bulk pricing. That is for the splitter. There would also be an adapter required to get the right GPS connection, but I have also located that part.
It would come with the connections sealed with heat shrink tube and would basically require you to unplug your current setup and put this splitter behind the radio. I can buy the cables separately, but the splitter is in bulk and I thought I would check here before I wind up with yet another drawer full of parts.
My question is: how many of you would be interested in something like this at a price point of $20 shipped?
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 06-06-2015, 01:45 PM   #2
Commercial Member
au01st's Avatar
Well, ordered the parts this morning. But it looks like people are happy to run another wire and mount an antenna.
Sent from my #racecar
Old 06-11-2015, 09:53 AM   #3
Commercial Member
au01st's Avatar
So, for anyone interested, got the parts yesterday but couldn't install until this morning. I'm usually very cynical about plug and play stuff working, but I'm happy to report that this worked perfectly. I unplugged my Sirius connection from the stock radio, placed the splitter in line, connected the GPS adapter, and plugged it all back in. It works! The satellite radio connection has no degredation or problems as I scanned thru the channels. The GPS works better than before. The one thing I noticed is that I no longer get the satellite icon with the option to check for how many satellites are connected.
ID:	184571   Click image for larger version
Old 06-11-2015, 01:42 PM   #4
Devil Strider's Avatar
My car doesn't have a sat antenna.
Sent from my SM-N910P using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
Old 06-11-2015, 02:27 PM   #5
Commercial Member
au01st's Avatar
Then you still need the GPS antenna. Lol
Old 06-11-2015, 02:40 PM   #6
I have the raxiom nav unit as well.
Old 06-11-2015, 04:56 PM   #7
Commercial Member
au01st's Avatar
Yes but do you have the connections for factory satellite radio on the back of the radio unit? It taps into the factory satellite antenna. I imagine the factory sat/nav display that uses the factory antenna is able to pick up both sets of satellites, so this just splits that signal.
Old 08-10-2015, 02:08 PM   #8
Alerotaz's Avatar
I would be interested in getting rid of the extra magnet off the back of my Car!!!.
PM me for a price or email ( Alerotaz@aol.com) ship to 38464.
Thank you
Alerotaz is offline   Reply With Quote
Old 10-09-2015, 04:34 PM   #9
Legit
Bought one and shipped next day. Works perfectly. Thanks for selling these man, couldn't find this part anywhere else
Pwnrofdanub is offline   Reply With Quote
Old 10-20-2015, 07:03 PM   #10
Commercial Member
au01st's Avatar
Got more of the extension pieces I needed in from overseas!
Old 11-16-2015, 05:05 PM   #11
got one and it works awesome. this is the only reason I purchased the raxiom gps unit. I did not want the extra antenna and this solved it.
vartech is offline   Reply With Quote
Old 11-16-2015, 08:30 PM   #12
Commercial Member
au01st's Avatar
Glad you like it. Working with a supplier to see if I can get the GPS cable in a longer length. Currently the only feedback I've received is that it can be tricky to get it to fit as you have to reassemble in the right order to have enough slack to reach the GPS plug on the Raxiom.
Have one left ready to ship before I place another order of cables.
Old 11-18-2015, 08:40 AM   #13
GTGirl's Avatar
I have Sirius so I am assuming I have a satellite antenna. I want to put in the Raxiom Navigation system as my car didn't come with the Navigation Package. Are you telling me there will be another antenna to add just for the Raxium? I hadn't heard that was necessary. I won't be doing it until next year as my GT/CS is a Vert and in winter storage but plan on doing some cross country travel next summer and would like to have the Raxium Nav. System. I am confused.
2 2014 Mustang GT/CS Premium California Special Race Red 1 Convertible Black Top
1 Coupe with Panoramic Roof and Navigation System
Vert Pioneer's 8100NEX and back-up camera
Both Vert and Coupe 6 speed Corsa Sport Axleback GT500 Quad Exhaust, comfort package
GTGirl is offline   Reply With Quote
Old 11-18-2015, 09:08 AM   #14
Yes you need a gps antenna. Or use the splitter cleaner install.
Old 11-18-2015, 10:27 AM   #15
Strange Mud's Avatar
it sounds to me like au01st is using the factory sat antenna (lump on trunk). that seems to be his point. He's been here a while and I trust him. Just make sure in a PM that I'm reading it correctly.
Old 11-18-2015, 10:01 PM   #16
Commercial Member
au01st's Avatar
Mud, you are correct. In factory nav equipped cars there is a single antenna for the GPS and satellite radio. After some research I discovered that the antenna receives signals from multiple satellites for each system. Every car that is equipped with satellite radio also has the capability for GPS because of the way Ford separates the signal at the radio (older models may have this splitter unit in the trunk so I can't vouch for 05-09 satellite radio equipped vehicles).
The Raxiom manual states that it is possible to tap into the factory antenna but they provide no instruction nor parts that make this possible.
If you have a satellite radio equipped vehicle but don't use it, you can still use the factory antenna for GPS with the right adapter. If you don't have an adapter or splitter then you will have to run a second antenna (I originally kept mine run to the glovebox and just put it on the dash when I needed it). In my opinion this part should have come with the Raxiom kit, but talks with AM to carry it have gone nowhere. Seems they are happy to deliver a 95% complete product.
And yes, I've been here a while, not going anywhere, and have delivered probably 20-25 of these units with every one making the Raxiom owner happy to have a product like it should have come.
Old 11-19-2015, 07:34 AM   #17
GTGirl's Avatar
I won't be buying it till next year - I will pm you when the time comes and if you have that splitter - I would be happy to buy it. I don't want to have to mount something to the windshield or the dash. I am glad to find out about this before we actually went and bought it. We have relatives that run a shop The RingBrothers actually. When I put on my Corsa's and valance they did it. And I am sure they would install the Raxium for the family discount too. LOL. Hard to believe they are so famous. They are finishing up a car for Jay Leno an early Mustang Fastback I think. It was all in pieces but my husband took a picture of the picture of the finished product. Talented guys - grew up next door to my husband. They are first cousins. I love they have touched my car! I have a hat with their autographs on it that I like to wear when I drive with the top down! Black and Red Hat to boot. Oh well that will be 5 months off.
Old 12-01-2015, 09:04 AM   #18
sbeard73's Avatar
PM Sent
sbeard73 is offline   Reply With Quote
Old 12-01-2015, 09:52 AM   #19
Commercial Member
au01st's Avatar
Replied. May be able to get it out today if you pay before I go to the post office.
Old 12-01-2015, 11:24 PM   #20
sbeard73's Avatar
You should sell alot of these being AM had the Raxiom Sync for 499.99 & Non Sync for 359.99 for a 3 day Black Friday Sale. I know they completely sold out Thursday and got more in on Friday afternoon. So there's lot of new one's out there, I'll help spread the word.
Old 12-02-2015, 01:24 PM   #21
Crews's Avatar
PM Sent.
Crews is offline   Reply With Quote
Old 12-02-2015, 03:57 PM   #22
Commercial Member
au01st's Avatar
Haha, if I sell out I'll be happy to help. I don't make but like $1 on these things.
Oh, cleared out my inbox. Saw it filled up today!
Old 01-30-2016, 10:01 PM   #23
Region: New Mexico
PM Sent
Just what I'm looking for! PM sent.
NewMexico is offline   Reply With Quote
Old 02-09-2016, 05:11 PM   #24
Commercial Member
au01st's Avatar
I have one more of these ready to go out.
I had to switch suppliers in China. Lead time is now 21 days instead of 10 days. But the cost stayed the same.
I'll also be moving this month so I don't want to make another order until I have my new address.
Old 04-14-2016, 01:11 AM   #25
jj4life24's Avatar
Is everything plug and play? (Splitter)
jj4life24 is offline   Reply With Quote
Old 04-17-2016, 09:54 AM   #26
king_13's Avatar
Still making them? In interested in one.
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 04-17-2016, 11:15 AM   #27
king_13's Avatar
Old 04-17-2016, 12:50 PM   #28
jj4life24's Avatar
Same here
Old 04-19-2016, 03:02 PM   #29
GTGirl's Avatar
I was going to get the Raxiom but spent a bit more money and got Pioneer 8100 NEX with Scosche Install Kit and a Back-up camera. I'm loving mine. I bought one of the au01st's set-ups and my installer used it. Works great. Much much nicer stereo than the stock too!
Old 04-19-2016, 05:45 PM   #30
jj4life24's Avatar
Do you know the name of the splitter?
Old 04-19-2016, 05:46 PM   #31
jj4life24's Avatar
Do they still sell them?
Name:	ImageUploadedByMustang Evolution1461109595.482976.jpg
Old 05-02-2016, 06:12 PM   #32
Commercial Member
au01st's Avatar
Alright, I know it took a while. Between moving and switching suppliers I had a few hiccups, but I have more of these ready to ship out. I have sent PMs to those who expressed interest or sent me a PM.
Contact me if interested. Feel free to post if you have one and like it. IMO, this is something that should have come with the radio...
Old 06-07-2017, 08:11 PM   #33
still have the spliter
Do you have anymore of the spliters I just got the raxiom navi unit and a factory gps antenna and do you know where to get the plug from the trunk to the front for the factory gps antenna?
MustangNurse is offline   Reply With Quote
Old 06-14-2017, 04:30 PM   #34
Region: New Mexico
I recently installed a Pioneer AVH-4800BS in my 2007 GT, along with the sirius module. The shaker unit I took out had the sirius option in it. I want to use the stock sirius antenna on my trunk rather than run another antenna somewhere on the car. If this splitter would work for me, I'll take one.
rogcat1 is offline   Reply With Quote
Raxiom GPS antenna placement special5.0 AmericanMuscle 6 11-18-2015 09:00 AM
Satellite antenna for shaker 500 swap Fastkurve 2011-2014 Mustang GT 9 04-06-2015 07:29 PM
is it hard to install a factory 2010 to 2013 mustang gps radio manlaw38 2011-2014 Mustang GT 13 03-27-2013 08:57 PM
Satellite Antenna Plug Delta vt 2011-2014 Mustang GT 0 01-04-2012 12:44 PM
12:13 PM
