Amp install - Mustang Evolution
Old 06-11-2015, 06:11 AM   #1
Noodles76's Avatar
Amp install
Hey guys I just traded in our truck and got my wife a new car. So I now have the amp and sub from the truck and I'm planning on installing it on my 2014 GT. My question is where is the best spot to run the power wire through the firewall. Any suggestions are greatly appreciated.
Rollin' in my 5.0
Noodles76 is offline   Reply With Quote
Old 06-11-2015, 06:25 AM   #2
Cooolbreeez's Avatar
This should help, I followed this minus removing the back seats and it was a breeze. How To: Add a sub and amp to a 2013 - MustangForums.com
Cooolbreeez is offline   Reply With Quote
Old 06-11-2015, 06:31 AM   #3
The only thing I did different was I didn't remove the bottom rear seat. I used the semi rigid/ flexible end of an old fishing pole to pull the wire through. I just shoved the fishing pole under the rear seat from the trunk side until it showed on the other side of the seat, taped the wire to it and pulled it through.
Old 06-11-2015, 04:45 PM   #4
Noodles76's Avatar
Awesome thanks for the help!!
Rollin' in my 5.0
Old 06-12-2015, 12:33 AM   #5
No prob man be sure and post up your results.
Old 06-12-2015, 05:05 AM   #6
Noodles76's Avatar
Ya I may document it with some photos so people don't have to go to the other link. Hopefully I'll get to it Monday or Friday next week.
Rollin' in my 5.0
Old 06-12-2015, 05:10 AM   #7
Stangholio's Avatar
I removed the back seat bottom. Pops right out. Pretty neat that are cars have that grommet ready for a power cable.
GHIGitty
Stangholio is offline   Reply With Quote
Old 06-12-2015, 11:20 AM   #8
Noodles76's Avatar
Yes my f150 had it too. Makes the install a little cleaner and easier.
Rollin' in my 5.0
Old 06-13-2015, 07:44 PM   #9
20prima10's Avatar
Pretty easy instal on these cars if you have done one before. Biggest think is making sure you have a good ground. If you have the light up door sills be very careful pulling these. They have extremely short wires.
20prima10 is offline   Reply With Quote
Old 06-18-2015, 01:47 AM   #10
Compstall's Avatar
I popped a hole in the sound tube and ran the power wire into it. Nice and clean.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 06-19-2015, 12:24 AM   #11
Noodles76's Avatar
Got everything wired up but hit a snag with the install. The amp is not powering up but I suspect a bad ground connection. I'll be back at it tomorrow.
Rollin' in my 5.0
Old 06-19-2015, 12:26 AM   #12
Good luck. Shouldn't be that hard. Where did you ground it at?
Old 06-19-2015, 03:41 AM   #13
Noodles76's Avatar
I used the bolt for the child restraint under the passenger side rear seat.
Rollin' in my 5.0
Old 06-19-2015, 03:51 AM   #14
20prima10's Avatar
Pull your remote wire from your antenna. Easy access to it. The ground I would recommend drilling sanding paint and running a bolt through the trunk. I tested the ground at the same location you are using and it wasn't very good.
Old 06-19-2015, 05:17 AM   #15
Noodles76's Avatar
OK I'll try the ground in the trunk. No need for a remote wire the amp has an auto on with frequency that worked OK in the truck. Trying the other spot now.
Rollin' in my 5.0
Old 06-19-2015, 08:30 AM   #16
20prima10's Avatar
That's just asking for something to go wrong lol. No wonder why the amp won't power up.
Old 06-19-2015, 08:39 AM   #17
20prima10's Avatar
If the amp has an option to use remote than I would use it. It's only 1 extra wire and will ensure that is not your problem of the amp turning on.
Old 06-19-2015, 11:06 AM   #18
Noodles76's Avatar
Got it figured out one of the speaker wires did not get proper connection with the tap I used. It's up and running time to clean up all the mess. Thanks for all the advise and help.
Rollin' in my 5.0
Old 06-28-2015, 03:49 PM   #19
GtrTech's Avatar
Has anyone done this with a 2015?
The war is coming to the streets of America and if you are not keeping and bearing and practicing with your arms then you will be helpless and you will be the victim of evil.
Ted Nugent
GtrTech is offline   Reply With Quote
Old 06-28-2015, 04:56 PM   #20
Noodles76's Avatar
I would venture to say it's similar but maybe Google. I'm sure someone has done an install by now.
Rollin' in my 5.0
Old 06-29-2015, 01:40 AM   #21
GtrTech's Avatar
If they have I haven't found it,about the only thing I've found out is don't mess with the radio fuse #33,seem to mess up the sync and other radio functions.
I have found where someone tapped fuse 36 Auxiliary body module,anyone tell what that is?
Ted Nugent
Old 06-29-2015, 02:54 AM   #22
Noodles76's Avatar
What are you trying to do just install an amp?
Rollin' in my 5.0
Old 06-29-2015, 03:24 AM   #23
GtrTech's Avatar
yes,just trying to find a source for the remote power.
Ted Nugent
Old 06-29-2015, 04:09 AM   #24
Noodles76's Avatar
Check and see if the antenna is similar. Also you could call an install shop or crutchfield they may be able to offer a little insight
Rollin' in my 5.0
Old 06-29-2015, 04:49 AM   #25
20prima10's Avatar
Your antenna will be a good place to pull 12v from
Old 06-29-2015, 04:50 AM   #26
20prima10's Avatar
You can easily do the antenna or rear lights. You just need the schematic for the rear lights if you go that route. You could even do your license plate lights if you wanted to. There all easy to get at. Your easiest bet though will be the antenna
how hard to install o/r x pipe? how much to get x pipe install? MustangForEver 2011-2014 Mustang GT 9 02-05-2013 07:01 PM
94 Mustang runs worse after CAI & coil install, Need suggestions Mustang52 1979-1995 Mustang GT 5 09-21-2012 11:22 PM
amp install Cp3 Mustang Audio & Video 3 04-20-2012 11:08 PM
C&C Plate install Gerry52 Pre-2005 V6 Mustang 0 12-13-2008 11:32 AM
2001 gt mach stereo sub & amp install gwilkrrs Mustang Audio & Video 2 07-08-2008 06:09 PM
04:48 AM
