custom dash panel - Mustang Evolution
Old 12-22-2015, 02:44 PM   #1
scott_0's Avatar
custom dash panel
I'm in the middle of making my own custom dash panel, one that places the head unit on top where it belongs. I started with an ADS MUS1 dash kit (I'm moving away from the Kenwood, so I will not need the climate control button row) and a Scosche dash kit for the climate control panel and electronics. I wanted to retain the pocket and the dual usb ports the MUS1 dash kit offers, so I cut the screen opening out, moved it to the top, then put the Scosche climate control panel below that. I used JB Weld plastic putty for the screen opening, and regular JB Weld for the climate control panel as I felt it needed some strength since the buttons will see some force. I filled in the seams with regular old 3M Bondo body filler, sanded like mad, them filled any pin holes or minor imperfections with 3M Bondo glazing putty, sanded some more, layed on a light coat of filler putty to find imperfections. I'm pretty happy where the panel is at this point. I plan on hitting it with atleast two more coat of primer, a touch more sanding then paint. does anyone know what color Ford uses on these interior parts? I need to thank RobDis from themustangsource.com for the inspiration for this project. any questions, thoughts or input is welcomed. here's a few pics:
here's a couple pics to show how much higher the screen will be than it is presently
I'm pointing to the top of the screen here
Sent from my S6 using tapatalk
Old 12-22-2015, 03:27 PM   #2
oxford5pointoh's Avatar
Nice job so far man. I started doing a custom one at one point myself but I never seemed to have the time (around the holidays last year) so I just went with a kit. I am anxious to see how it turns out for you.
Old 12-22-2015, 03:52 PM   #3
scott_0's Avatar
thanks man! hoping I have a finished product in the car by the new year, I have a Pioneer Avic 8100NEX ready to replace the Kenwood in the car now
Old 12-22-2015, 06:07 PM   #4
Senior Member
rlma84's Avatar
I did some custom work to mine so I could put a tablet instead of the ugly radio buttons and nobs
Sent from my SAMSUNG-SM-N920A using Tapatalk
rlma84 is offline   Reply With Quote
Old 12-24-2015, 01:49 PM   #5
scott_0's Avatar
even though I ordered a can of Sem 39033, I decided to try another color I found at autozone, it is duplicolor perfect match gun metal metallic
Old 12-24-2015, 01:58 PM   #6
That looks great man. Very nice job
Old 12-24-2015, 02:20 PM   #7
scott_0's Avatar
thanks man! I really appreciate it
Old 12-27-2015, 10:01 AM   #8
scott_0's Avatar
finished product!
Old 12-27-2015, 10:06 AM   #9
I like that a lot man. Looks like maybe you can still see where the cut was made though? What happened there?
Old 12-27-2015, 10:50 AM   #10
natestang07's Avatar
Where are you seeing that?
Old 12-27-2015, 10:55 AM   #11
scott_0's Avatar
you can, it happens sometimes with body filler, I'm going to address it when I put the actual paint I'm using on it and clear coat it
Old 12-27-2015, 11:01 AM   #12
You can basically see the outline of the cut around the top. I wasn't trying to be a dick or anything.
Old 12-27-2015, 11:13 AM   #13
Ahhhhhhhhhh that's what that is
Old 12-27-2015, 11:16 AM   #14
scott_0's Avatar
yup, I didn't take it that way at all man, appreciate the feedback
yes sir, it's minor but there none the less
Old 12-27-2015, 11:18 AM   #15
I had to actually look closely to notice it.
Old 12-27-2015, 11:26 AM   #16
I really like the placement. Comparing it to mine...
Name:	ImageUploadedByMustang Evolution1451240789.012158.jpg
Old 12-27-2015, 11:27 AM   #17
I think it looks pretty d*mn good. Nice job.
la pantera is offline   Reply With Quote
Old 12-27-2015, 11:38 AM   #18
Stand up and Scream> Everything else AA has put out
Old 12-27-2015, 11:50 AM   #19
Cooolbreeez's Avatar
What stereos are you guys running?
Cooolbreeez is offline   Reply With Quote
Old 12-27-2015, 12:52 PM   #20
scott_0's Avatar
yeah man, love the quality of the Scosche kit but could not bring myself to mount the headunit that low, I do however miss the outside temperature reading the information screen provided
thanks man!
I'm running a Kenwood DNX890HD, but will be moving to a Pioneer AVIC 8100NEX in a few weeks
Old 12-27-2015, 03:37 PM   #21
I might have to copy you on this. I think I might keep my temp/compass and maybe mount it in the middle. So many possibilities.
Old 12-27-2015, 03:56 PM   #22
scott_0's Avatar
do it man! I tossed over keeping the information screen and moving it down, but the pocket with the dual usb ports won out for me
Old 12-27-2015, 04:00 PM   #23
How did you mount the radio? Same brackets only moved it up?
Old 12-27-2015, 04:07 PM   #24
scott_0's Avatar
I used the brackets that came with the Scosche kit, but they needed to be modified to fit up top, there was some trial and error in placing new holes to mount the unit, the old information screen mounting area is wider than the other mounting location so you have to take that into account, but I simply moved the head unit side to side so it was even, there is plenty of play to do so. if you decide to move forward, it will be straight forward because you're using all the pieces from the same kit, you're just moving them around. as long as all your cuts are pretty straight, it will go smoothly. let me know if you have any questions
Old 12-27-2015, 04:22 PM   #25
Will do. It will be a month or so before I can do this because all my tools are in limbo as I'm moving.
Old 02-15-2016, 12:54 PM   #26
Lion's Avatar
Not bad)
Lion is offline   Reply With Quote
Old 02-15-2016, 01:16 PM   #27
Sterlingbeast5.0's Avatar
nice. very nice. man you did good looks professional.
Old 02-15-2016, 02:11 PM   #28
scott_0's Avatar
Originally Posted by Lion View Post
Not bad)
thanks fellas, I still haven't put the final touches on it with some touch up sanding and laying a few coats of Sem 39033 and clear, soon as the weather breaks
Old 03-16-2016, 12:33 PM   #29
GTGirl's Avatar
This is a Scosche dash kit for the climate control panel. Would prefer the head unit up higher but I like the screen on top still giving direction and temperature. This is a 2015 Pioneer 8100 Nex unit. I really like it
Took the picture after I had turned off the car so that is why climate controls aren't showing. And the temp outside.
2 2014 Mustang GT/CS Premium California Special Race Red 1 Convertible Black Top
1 Coupe with Panoramic Roof and Navigation System
Vert Pioneer's 8100NEX and back-up camera
Both Vert and Coupe 6 speed Corsa Sport Axleback GT500 Quad Exhaust, comfort package
GTGirl is offline   Reply With Quote
Old 03-16-2016, 12:45 PM   #30
seriously no chance in hell I could ever even start a project like this. Very cool man!
Old 04-30-2016, 08:19 AM   #31
scott_0's Avatar
not sure if anyone is interested, but I traded my car in last Thursday, Im selling this dash panel and the ADS Maestro RR if anyone is interested, shoot me a PM. I never updated this thread, but I have since sprayed the panel with Sem 39033 which is nearly a perfect match, it looks awesome now!
Plasti dip dash/ remove airbag cover dash panel austin0324baird Mustang Paint, Appearance & Detailing 4 05-26-2014 10:59 PM
Please help! need to remove instrument panel left side panel Peruano_loco 2011-2014 V6 Mustang 5 02-02-2014 08:24 AM
Help! Im trying to remove dash Panel on The passenger-side curtin1991 2011-2014 V6 Mustang 18 01-05-2013 07:43 AM
2010+ aftermarket stereo dash panel white sally Mustang Audio & Video 2 11-22-2010 11:47 AM
86 svo mustang header panel wanted header panel? wit 2.3 Mustang 1 08-21-2009 07:39 PM
12:31 PM
