Audio wiring help. - Mustang Evolution
Old 04-21-2016, 05:33 PM   #1
Slickmullet's Avatar
Audio wiring help.
So I have 2 wires in the trunk, I assume a positive and negative. I also have a set of RCA jacks in the back. There is a volume control on the dash. There is a power wire with fuse in the engine bay duct tape to the side. There is no negative. I assume this was a setup for a sub for the stock system. Is there no negative needed in the engine bay?
I'm looking to add a powered sub.
Slickmullet is offline   Reply With Quote
Old 04-24-2016, 09:14 AM   #2
wmschoonover's Avatar
No negative is needed in the engine bay since the vehicle body is the ground, hence the ground in the trunk. As for the volume control, you will need a compatible amp or powered subwoofer to use that since not all use them. You can only assume they left the RCA adapter behind the radio if still stock since they left the rest of the wiring. So in theory, you should be able to get either a powered subwoofer or an amp and subwoofer and plug up the connects, reconnect the power in the engine bay and enjoy.
wmschoonover is offline   Reply With Quote
Old 04-24-2016, 10:53 AM   #3
Sounds good. Thanks.
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
Car Audio Wiring - Help Needed! ChrisxF Mustang Audio & Video 2 06-04-2008 11:42 AM
audio help 1997grnstang Mustang Audio & Video 8 05-19-2004 10:44 AM
audio noob needs help Monkey Mustang Audio & Video 21 11-23-2003 08:57 PM
02:21 PM
