Fogged up headlights - Mustang Evolution
Old 03-05-2004, 08:02 AM   #1
I bought a set of Smoked with white, not orange reflectors from procarparts.com. I like them, but they fog up every morning and its way worse when it rains. They never unfog either unless i take them out and let them dry for a day or so.
I've oiled the gaskets around the bulbs to make sure they seal and I've also used silicone glue around the entire headlight lense and this still happens.
Its driving me nuts and procarparts says they won't take them back or refund me because they are not a warrantied part. I guess the headlights are made by some generic manufacturer in Taiwan.
Any suggestions would be appreciated.
2000 Black V6, 5spd, 1.8 Roller Rockers, Mac CAI, Mac Longtube Headers, Mac Off-road H-pipe, Flowmaster Force II Catback, Ford T-lok (on 2nd one), 3.73 gears, LUK Clutch, MM pedal height adjuster, Ford Aluminum D/S, Eibach Pro Kit Springs, Koni Yellows, HPM Megabite Jr LCA's, Cross-drilled/slotted rotors (11" F, 10.5" R), S/S brake lines, Eibach front/rear sway bars (1.25" F, 1" R), Pro 5.0 Shifter with Steeda Tri-Ax handle, ROH Snyper rims (17x8 F, 17x9 R), Kumho Ecsta 712's (245/45/17 F, 275/40/17 R), GT fog lights, Smoked/Cleared Headlights.
Testicleez is offline   Reply With Quote
Old 03-05-2004, 08:26 AM   #2
01mineralgrey6's Avatar
I've heard that some rice in the headlight housing will absorb some moisture.
-Tony
'99 cobra 'vert
Old 03-05-2004, 08:42 AM   #3
Danger Dude's Avatar
First question I have is does you headlights have a vapor tube coming out the back. this is there to allow the vapor to evaporate out when you turn on the lights and heat the lenses up. if it does. take the headlight off the car. Take them inside and where the bulb went in the back blow hot air in it using a hair dryer. once the moisture is gone seal the vapor tube with silicon.
If it does not have a vapor tube on the back dry it like I said a check your sealing again.
Old 03-05-2004, 08:59 AM   #4
Black95GT's Avatar
Send a message via AIM to Black95GT
LMAO
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 03-05-2004, 09:01 AM   #5
no really. same reason that people put rice in salt shakers. :dunno:
-Tony
'99 cobra 'vert
Old 03-05-2004, 10:31 AM   #6
I have the vapor tubes. I've already sealed them once with silicone and it didn't help. I was hoping by opening the tubes it would allow the water to evaporate out.
I'm honestly stumped and angry. It makes the whole car look like ****.
Old 03-11-2004, 06:57 PM   #7
tahts the only way to get rid of it is to have a tube in the lights make sure it curve so nohti you fly in there easily but then itll be fine
Choppa is offline   Reply With Quote
Old 03-11-2004, 07:05 PM   #8
Shahrum's Avatar
Send a message via MSN to Shahrum
LMAO
I've got plenty of rice if you need some
Shahrum is offline   Reply With Quote
Old 03-11-2004, 08:11 PM   #9
-Tony
'99 cobra 'vert
Old 03-20-2004, 05:59 PM   #10
Ponycarman's Avatar
btt
1996 Mustang
1965 Barracuda
Originally Posted by slvr2000stang
Holy crap he's right.
Ponycarman is offline   Reply With Quote
Old 03-22-2004, 07:38 AM   #11
Concordium's Avatar
i did my headlights yesterday. just remove the bulb from the headlight unit and take a hair dryer and put it on high till the water evaporates (or the dryer burns out) when your done immediately put the bulb back in a seal it up good. make sure to seal up the evaporation tube before you try drying out the headlight.
Silver '96 V6
Mods: True Dual Exhaust, Flowmaster 40's, Cobra Diamond Clear Headlights and Side Markers, Shortened Antennas, Blue Dome Light, Metallic Blue Painted Calipers, 4.10's w/ T-Lok coming in a few weeks.
http://www.mizzoustud.com/pics/conc.png
Concordium is offline   Reply With Quote
Help. Headlights On 95 Rollin Thunder 1979-1995 Mustang GT 18 04-04-2008 11:04 PM
headlights? chuck_918 1979-1995 Mustang GT 2 01-28-2008 12:42 PM
Which headlights should I get? Seph The Bar 17 11-07-2007 11:03 AM
Looking for headlights V6Polish Pre-2005 V6 Mustang 6 07-28-2007 04:06 PM
My Headlights Black95GT Pictures and Videos 11 12-08-2004 08:23 PM
06:54 AM
