replacing a mirror - Mustang Evolution
Old 03-07-2004, 12:29 PM   #1
Send a message via AIM to mexor
replacing a mirror
my right mirror is broken anyway i bought a new one on ebay, is it just pretty much, rip out the mirror (no screws, just pop on/pop off). just don't wanna break anything
-dave
mexor is offline   Reply With Quote
Old 03-07-2004, 12:32 PM   #2
Uh.. Are you talking about the mirror glass itself or the mirror housing?
Laser02 is offline   Reply With Quote
Old 03-07-2004, 12:34 PM   #3
the mirror housing .. the plastic is completly ripped, barely hanging on.
Old 03-07-2004, 01:23 PM   #4
The housing is easy to replace. In the inside of your door there is a little triangular shaped cover where the Mach 1000 tweeters are supposed to go. Pop that off. There are 3 bolts under that.. Take those out and the mirror housing will just come right off.
Old 03-07-2004, 02:09 PM   #5
ok i could take off the mirror pretty much, but its still being held on by the wire ..how long is this? do i have to take apart the door to unplug it?
Old 03-07-2004, 02:27 PM   #6
Heh. Trying to remember...
I believe there is a connector for that wire under the door panel that you can unplug. The door panel is easy to remove though.
Old 03-07-2004, 02:35 PM   #7
how do you remove the doorpaneL?
mirror that i bought:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=33649&item=2464181460
looks like it'll be deep into the door panel...
Old 03-07-2004, 03:23 PM   #8
Dom
Dom's Avatar
Send a message via AIM to Dom
Ohh! Ohh!
Pop off the door cup panel. There wil be two screws on the panel. Take them off. Pop the door handle bezel out. It's held on with pressure. Pop out the clip on the inside of the door panel. Can't miss it. It's black. And then push up on the door panel. And unplug the harnesses. Don't forget to take off the sail panel. You, know. That black panel where the MACH 460 Tweeters go.
Old 03-07-2004, 04:41 PM   #9
is there any how-to on taking off a door panel? i tried it and i got nowhere...where are the 2 screws? thanks
-dave
Old 03-07-2004, 05:05 PM   #10
The two screws are underneath the door handle bezel. Take those out. Then on the outside of the door panel near the latch there is a clip. After that, pull up and it will come right off.
Old 03-07-2004, 07:00 PM   #11
sure first you take your arm rest panel off where your window controls are. Pop it uff with a screw driver but be careful not to break the connectors
When you have that off you take the door handle bezel off crefully. Now you should see three screws where your arm rest panel was. Take those out. Now from the bottom of the door lift up on the door and it will slide up. Then pull away from you slowly. Then reverse to put back on.
If i have confused you I am sorry I tried lol
Thats my how to
Old 03-07-2004, 07:26 PM   #12
Region: New Hampshire
Send a message via AIM to Smokedya95stang
its a pain i've done this before.
Thats how i broke my door armrest thing, so i had to replace it.
How the power switches are connected to the armrest are freaking fragile!
Its like the tiniest plastic thing, and they just stnapped off the armrest when i lifted up on it to unplug, very gay. So watch out when u take if off.
-Charles
Smokedya95stang is offline   Reply With Quote
Old 03-07-2004, 07:35 PM   #13
They must have had P.O.S. handle bezels in 95 or something... I've taken both of my doors off like 6 times to fix windows and dynamat and install speakers. It's so simple. And nothing has ever come close to breaking.
Old 03-07-2004, 07:43 PM   #14
they must of...
i flipped them upside down to unplug the swtiches and looked at it, and the little plastic things were broken. unless it was already broken.
i was like poop.
I handled with care man!
-Charles
Old 03-07-2004, 07:48 PM   #15
Dom
Dom's Avatar
I only had two. :
It's way easier than taking the door panel off on a 98 than in a 67. Cardboard and metal clips.
Mirror replacement BMustang1 Pre-2005 V6 Mustang 5 09-23-2008 06:38 PM
Help Replacing Mirror Buck Pre-2005 V6 Mustang 6 09-23-2008 11:22 AM
tires like mirror carlosc Mustang Wheels & Tires 22 01-26-2008 02:03 PM
Mirror Bulbs Mustang414 Mustang Audio & Video 1 05-18-2005 09:51 PM
Mirror! red herring Mustang Parts for Sale and Wanted 6 04-14-2005 02:49 PM
03:15 PM
