Impedance - Mustang Evolution
Old 05-09-2004, 05:14 PM   #1
Impedance
Is it better to have a sub at high higher or lower impedance when wiring it to the amp. I have a dual coil 4 ohms 12'' kicker.
Dave is offline   Reply With Quote
Old 05-09-2004, 05:46 PM   #2
Black95GT's Avatar
Send a message via AIM to Black95GT
the lower ohms you wire it at, the less amount of resistance you get, so it will get more power at lower ohms, I think with a 4 ohm u can only wire it to 1 ohm or 4 ohms, dual 2 ohm are alot better for wiring in different configs
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 05-09-2004, 08:57 PM   #3
You can wire Dual Voice Coil Subs that are 4ohms either to 1ohm, 4ohms, or 8ohms.
When you are picking a amp for your subs you need to find a amp tyhat puts out the power you want at 1 or 4ohms.
Old 05-12-2004, 05:43 PM   #4
I went to sound domain and it gave me the options of wiring the sub to a mono amp at 2 ohms if I connect the sub in parallel. Thisis where I got the information
http://www.sounddomain.com/sku/KIC03CVR124
just click on subwoofer wiring options
Old 05-12-2004, 07:51 PM   #5
Yea you can wire one (1) Dual 4ohm Voice Coil Sub to 2ohms. If you add a one (1) more sub to your system and you wired it in parellel it drops it to 1ohm
02:55 AM
